GReddy Profec Oled
berg
Anyone using one of these boost controllers?
I need to know if it also displays boost like a boost gauge does while driving?
It doesnt seem to say anywhere unless im blind
Im looking for something that is a gauge/controller in one to save having 2 seperate devices but i dont want the AEM Tru Boost
Excellent Ill be buying one then :)
My mines ecu is only set to 1bar and a factory rev limit so theres no point me keeping it, i have a stock ecu to go back in so ill be getting this controller to go with it!
Thanks
  • 2 months later...
Just a quick bump as im fitting mine tomorrow
Does anyone have any rough idea on what the settings should be for a BPU car to run 1.2bar?
I havent read the instructions fully but i see a few different values that need setting up, i thought i could literally just select the boost i want and that was it, seems a bit more complicated than that
It might just save me hours of fiddling
The only thing I remember changing is just the gain, I left everything else at 0
That's not the way to do it :)
The start and then the set are how you adjust the boost level, gain is to improve response. Having the gain set at a disproportionately high level to the set may result in boost spikes.
You can make the display show you the boost curve, that is much more useful in setting the levels than just looking at the peak figure :)
How Comes you don't want the AEM truboost? Are they crap? :D
