jza800 Posted June 11, 2014 Share Posted June 11, 2014 I have a 2jzgte, that shakes a littlebit.. when the engine is on idle you can see on the engine it shakes and you can feel the shake when you hold on the trottlebody, and it follows revs up to about 2000, but the higher you go up the rpm, the less it shakes, but it dosent stop shaking 100%.. the thinks i have checked.. new sparks plug compression test 180 psi on all 6 cyl on hot engine it sparks on 6 coil packs it fuel on all 6 gasoline nozzle i have ohm the coil packs, and they say 1.2Ω on all 8 on hot engine. the engine sounds healthy, and drive like normal.. the only thing is that is shakes.. where could the problem else be??? Link to comment Share on other sites More sharing options...
David P Posted June 11, 2014 Share Posted June 11, 2014 Engine mounts? Link to comment Share on other sites More sharing options...
jza800 Posted June 11, 2014 Author Share Posted June 11, 2014 i have checked the mounts and they seems to be fine.. but how is the best way to check them? Link to comment Share on other sites More sharing options...
David P Posted June 11, 2014 Share Posted June 11, 2014 With the engine running, watch or/and feel them. Link to comment Share on other sites More sharing options...
jza800 Posted June 11, 2014 Author Share Posted June 11, 2014 i have tried to look under the car when it idle.. and i can see the transmission shake too with the engine... the mounts look fine on both sides. there is the same Little slip on them both.. if you stand in the front off the car, it is like i shake more on the intake side.. the turbo side look come and steedy... Link to comment Share on other sites More sharing options...
David P Posted June 11, 2014 Share Posted June 11, 2014 Are they pre-Facelift or Facelift mounts? Link to comment Share on other sites More sharing options...
Abz Posted June 11, 2014 Share Posted June 11, 2014 If it's facelift then very likely it is the engine mounts. Link to comment Share on other sites More sharing options...
David P Posted June 11, 2014 Share Posted June 11, 2014 If it's facelift then very likely it is the engine mounts. You're a wellie wearing punch line pincher. Link to comment Share on other sites More sharing options...
Abz Posted June 11, 2014 Share Posted June 11, 2014 You're a wellie wearing punch line pincher. I like to get in quick David... I am hoping we could tag team him in!! Link to comment Share on other sites More sharing options...
Chris Wilson Posted June 12, 2014 Share Posted June 12, 2014 Check the crank damper isn't breaking up (Tipex test). If it has a none stock clutch and flywheel, particularly a CHEAP none stock clutch or flywheel, I have known them be wildly out of balance. If, at idle, you feel the vibration through the steering wheel, and it's a late model car ("facelift"), suspect the engine mountings though, as others have said. They'll LOOK fine, but probably be shot. Fit new early mounts and used early brackets, they give very little bother. Link to comment Share on other sites More sharing options...
Havard Posted June 12, 2014 Share Posted June 12, 2014 Engine mounts ftw..!! Link to comment Share on other sites More sharing options...
Fitz Posted June 12, 2014 Share Posted June 12, 2014 Its probably the car shaking, the engine is not moving at all..... Just kidding, Facelift engine mounts are cack, pre-facelift FTW! Link to comment Share on other sites More sharing options...
jza800 Posted June 12, 2014 Author Share Posted June 12, 2014 i found the problem, 3 spark plugs was not working correct. they spark, but not enough. so now it dont shake anymore.. Link to comment Share on other sites More sharing options...
Havard Posted June 12, 2014 Share Posted June 12, 2014 i found the problem, 3 spark plugs was not working correct. they spark, but not enough. so now it dont shake anymore.. Defo engine mounts OR what you said..!! H. Link to comment Share on other sites More sharing options...
SupraLEDrears Posted June 14, 2014 Share Posted June 14, 2014 i found the problem, 3 spark plugs was not working correct. they spark, but not enough. so now it dont shake anymore.. How did you test that? Link to comment Share on other sites More sharing options...
jazz1 Posted June 14, 2014 Share Posted June 14, 2014 TRD engine mounts FTW . Link to comment Share on other sites More sharing options...
