Facelift or uk headlights?
gannon888
I might have to disagree with you on this one Scott, each to there own though :)
I just see like the facelift rears, it's the contrast that makes it look better.
It's all just opinions bud. I got rid of the facelift rears in favour of black innards ;)
My facelift fronts are up the loft though :D
  • 1 year later...
See what I kinda don't like is when people 'facelift' pre/uk ones they paint the insert black... When the facelifts are actually a very dark gunmetal colour, not too different from the facelift rears.
If I was going to facelift mine then I'd want the exact same colour as the stock facelifts, I think just that small contrast against the black car makes a big difference.
Has anyone got a colour code for the facelift inserts?
Oh and yes.., I'm a picky fecker... :D
I'm looking for the insert paint code as I need to fix a defect on my facelifts before fitting. Anyone know what the code is? It's very similar to what I did my dash board in which was Toyota Dacuma grey. Would a dealership know maybe?
  • 1 month later...
Just opened up my facelift lights as the inserts have a bubbling paint defect under both fog lights and there is tiny bits of glass in the enclosure. Seems like a bulb exploded at some point in the past.. Anyway, I put the inserts up against Toyota Decuma Grey and it is not the same. Inserts are darker with what looks like more bronze. Found this on Supra forums when hunting for a paint code:
http://www.supraforums.com/forum/showthread.php?225703-Paint-code-for-97-98-painted-headlights
"under the 98 Toyota Dupont colors for trim there is several colors but none are called charcoal they just have difent shades of gray.
from darkest to lightest and the lightest is real close to a silver
Note these are all Metalic
Drk Gray Met # UC156 Microfiche # L8647
Drk Gray Met # UC1A45 Microfiche # L9708
Medium Gray Met # UCA76 Microfiche # F1114
Gray Met # UCA75 Microfiche # F1113
the non Metalic codes used mainly for underhood are:
Black 202 Microfiche #F0220
Off Black # 930B Microfiche # F2805
(what I would use for Inside of Lights)
Gray 4N7B Microfiche # F3779
Is they ask their Dupot Numbers
Like I stated I hope this helps some
Off black looks the best for the inside of the lights. My opinion"
Alright, managed to find the paint code for the facelift headlight inserts.
Manufacturer : TOYOTA
Code : 1A1
Colour name : DARK BROWNISH GREY
Stock code : L9991
Alt. : 0
Color Change :
Quality : CROMAX
Coat : 2 COAT
Finish type : Gloss
PB :
VS : vs7
Standard Date : 16/02/1993
Formulation Date : 27/01/1997
Take that code to Halfords or any shop that can mix paint and you'll have the original colour.
Edited by Delboy52 (see edit history)
Code : 1A1
Stock code : L9991
Alt. : 0
Color Change :
Quality : CROMAX
Coat : 2 COAT
Finish type : Gloss
PB :
VS : vs7
http://i34.photobucket.com/albums/d119/Delboy52/Supra/Facelift_Supra_Headlight_Insert.jpg
Nice find!:thumbs:
