Tim_v_M Posted April 28, 2010 Share Posted April 28, 2010 Hi all, Ever since I've my Supra I'm asking myself what some things are, why they are on my car, and if every Supra has them. Who knows what this is? : Its a small "thing" on the right on the dash. Can't push it down, it doesn't flash. (Also notice my freshly resprayed windscreenwipers ) http://img192.imageshack.us/img192/2396/foto0202j.jpg Under the dash, is a small red switch, when pushed the high beam goes on. Why is there such button as I can also do that with the indicator. http://img22.imageshack.us/img22/3686/foto0203t.jpg And last, a device at the left bottom of the frontwindow. When contact is on, there is a red light that glows. It says: "Interwave" on it. There is a cable that runs from it to the other half of the dash and than goes in it. http://img191.imageshack.us/img191/2053/foto0204d.jpg So, what is it, what does it do and does all the cars have those things? Thanks! Link to comment Share on other sites More sharing options...
dr_jekyll Posted April 28, 2010 Share Posted April 28, 2010 the switch will be your rear fog light. Link to comment Share on other sites More sharing options...
evinX Posted April 28, 2010 Share Posted April 28, 2010 All supras have that blob on the corner of the dash think its to do with the alarm sensor iirc? Link to comment Share on other sites More sharing options...
DamanC Posted April 28, 2010 Share Posted April 28, 2010 R2D2 = Climate Control sensor. Factors in direct sunlight to temperature sensing. Link to comment Share on other sites More sharing options...
Tim_v_M Posted April 28, 2010 Author Share Posted April 28, 2010 the switch will be your rear fog light. Thinks it's not as it switch on my high beam on (Hope that is how you call it in English) Link to comment Share on other sites More sharing options...
Matt H Posted April 28, 2010 Share Posted April 28, 2010 Could your third item be a snooper or some kind of camera detector? As said, the thing on your dash is a sensor for you climate control. The other thing is odd if it turns you full beam on, I'd presume it would serve as a rear fog switch if your car is an import. Link to comment Share on other sites More sharing options...
Tim_v_M Posted April 28, 2010 Author Share Posted April 28, 2010 Could your third item be a snooper or some kind of camera detector? As said, the thing on your dash is a sensor for you climate control. The other thing is odd if it turns you full beam on, I'd presume it would serve as a rear fog switch if your car is an import. Don't think its a camera detector, havn't heard it beeping or something at a speedcamera. The brand is Interwave i guess, but didn't find something for that name. Maybe the seller, JamieP, knows what it is... Link to comment Share on other sites More sharing options...
keron Posted April 28, 2010 Share Posted April 28, 2010 looks like a automatic headlight sensor to me...had a few with them on...has it got a button on it? and maybe on the side too? Link to comment Share on other sites More sharing options...
jackso11 Posted April 28, 2010 Share Posted April 28, 2010 (edited) Follow the wire from the thing in the bottom left of your window. I bet it goes to under the carpet and near the ecu, where you might find the remains of an old GPS unit used when it was in Japan. I had the same, covered in rust...due to my aerotop leaking in the past I reckon it will be the GPS receiver, the same as mine way. chucked it out. red switch, fog light that has been wired up incorrectly I would think. Blob on the right, climate sensor for your climate control. Edited April 28, 2010 by jackso11 (see edit history) Link to comment Share on other sites More sharing options...
creative Posted April 28, 2010 Share Posted April 28, 2010 is your interwave thingy something to do with a mobile device of some description? and I would say the switch is for your rear fogs... but wired up wrong! Link to comment Share on other sites More sharing options...
Stan Posted April 28, 2010 Share Posted April 28, 2010 looks like a automatic headlight sensor to me...had a few with them on...has it got a button on it? and maybe on the side too? If it says 'conlight' on it then it'll be one of these, if not then I dunno! Link to comment Share on other sites More sharing options...
Tim_v_M Posted April 28, 2010 Author Share Posted April 28, 2010 looks like a automatic headlight sensor to me...had a few with them on...has it got a button on it? and maybe on the side too? You're talking about the thing at my front window? It has no buttons on it. What I've just noticed is that there is a little wire that used to go to a small sticker on the window. (Isn't connected anymore) Follow the wire from the thing in the bottom left of your window. I bet it goes to under the carpet and near the ecu, where you might find the remains of an old GPS unit used when it was in Japan. I had the same, covered in rust...due to my aerotop leaking in the past I reckon it will be the GPS receiver, the same as mine way. chucked it out. red switch, fog light that has been wired up incorrectly I would think. Blob on the right, climate sensor for your climate control. Can't follow the wire as it runs behind the dash, but a GPS receiver could be so. I'll look soon if I can find some remains of a GPS unit. That switch thing, possible wired up incorrectly. However it only works when lights switched on, and also the "head beam indicator" on the dash lights up. is your interwave thingy something to do with a mobile device of some description? and I would say the switch is for your rear fogs... but wired up wrong! Don't know about any mobile device on the car... If it says 'conlight' on it then it'll be one of these, if not then I dunno! It doesn't say 'conlight'. So maybe it isn't one. Thanks all for the thinking! Link to comment Share on other sites More sharing options...
Soop Dogg Posted April 28, 2010 Share Posted April 28, 2010 Take a look at Interwave Global. They are in the business of "tracking of cell phones via GPS and Cells. Information via data and satelite maps." Could be something to do with one of their products? Link to comment Share on other sites More sharing options...
wile e coyote Posted April 28, 2010 Share Posted April 28, 2010 They are tracking you Link to comment Share on other sites More sharing options...
a98pmalcolm Posted April 28, 2010 Share Posted April 28, 2010 yer i always wondered what the lil blob on the dash was lol Link to comment Share on other sites More sharing options...
Tim_v_M Posted April 28, 2010 Author Share Posted April 28, 2010 Take a look at Interwave Global. They are in the business of "tracking of cell phones via GPS and Cells. Information via data and satelite maps." Could be something to do with one of their products? Could be, but can't find a picture of their products. But I think it is. They are tracking you Maybe i'll cut the wire XD Link to comment Share on other sites More sharing options...
Dave Posted April 28, 2010 Share Posted April 28, 2010 its not a broadband reciever is it ??? Link to comment Share on other sites More sharing options...
Ian C Posted April 29, 2010 Share Posted April 29, 2010 yer i always wondered what the lil blob on the dash was lol http://www.mkivsupra.net/vbb/showthread.php?t=35937 5 years that FAQ entry's been sat waiting for you Link to comment Share on other sites More sharing options...
mathew Posted April 29, 2010 Share Posted April 29, 2010 whilst we are on the topic of 'who know what it is' im still yet to discover what one particular switch on the dash does after nearly 4 years of ownership. its on the right hand side below the ignition, its round with a little red light on it. any ideas? Link to comment Share on other sites More sharing options...
Animal Posted April 29, 2010 Share Posted April 29, 2010 It'll be rear fog light Link to comment Share on other sites More sharing options...
