Red warning light!
danny1987
Break fluid or check oil level (can go low on an incline or such then go out).
The orange oil level warning light should come on also if it was that.
If it come on under braking then probably brake fluid level as said.
If it comes on at a certain speed, then it could be speedo convertor or front auto spoiler.
OP re the above you really need to check what warnings lights top left AND right (the usual probelm area) of the dash actually light up when you turn the ignition on.
