tbourner Posted June 22, 2009 Share Posted June 22, 2009 Would you cut a hole in your bonnet as well then? Quote Link to comment Share on other sites More sharing options...
The Raven Posted June 22, 2009 Author Share Posted June 22, 2009 Would you cut a hole in your bonnet as well then? Yeah i would, as was quite happy to. If i dont get any joy with this i will cut my own custom vent in the stock bonnet Quote Link to comment Share on other sites More sharing options...
Dnk Posted June 22, 2009 Share Posted June 22, 2009 Look at the pics again, there is the shape of the scoop moulded in, you would have to cut it free from the rest. Yes i noticed that, i think if you did that it would probably fall apart. Quote Link to comment Share on other sites More sharing options...
The Raven Posted June 22, 2009 Author Share Posted June 22, 2009 Yes i noticed that, i think if you did that it would probably fall apart. Like thats a bad thing? Quote Link to comment Share on other sites More sharing options...
Dnk Posted June 22, 2009 Share Posted June 22, 2009 Like thats a bad thing? If its on your bonnet at 70 mph or more and falls apart then yes Just a silly question, how does it attach to the bonnet, i cant see and threaded inserts or holes for the bolts to go in ? Surely not double sided tape Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted June 22, 2009 Share Posted June 22, 2009 The trouble is its not an airscoop is it, its just a lump of fibreglass that serves no purpose what so ever other than to make you look a dick if you fit it to your car Quote Link to comment Share on other sites More sharing options...
The Raven Posted June 22, 2009 Author Share Posted June 22, 2009 If its on your bonnet at 70 mph or more and falls apart then yes Just a silly question, how does it attach to the bonnet, i cant see and threaded inserts or holes for the bolts to go in ? Surely not double sided tape I have no idea how it was supposed to attach, its totally hollow. You couldnt even stick tape to it as it has no edge. As for falling apart, i belive if i was to try and drill out the vent bit it wouldnt stand up to it let alone 70mph:d Quote Link to comment Share on other sites More sharing options...
Soaruss Posted June 22, 2009 Share Posted June 22, 2009 I don't think its that bad considering, even some of the best name kits/parts need a bit of trimming. And that would take 15 mins of trimming and fettling to make it fit fine. Why is it people seem to think that all fibreglass bits should fit like a glove? it is NOT like metal, the process has a lot of variables that dictate the end result, parts can move about during and after drying dependant on storage conditions etc, so it gets blamed on whoever made the part, but it just doesn't work that way. And no i have no idea who made it, so I'm not sticking up for them, i just have a bit of experience with fibreglass. True Quote Link to comment Share on other sites More sharing options...
themodifiedkid Posted June 22, 2009 Share Posted June 22, 2009 The only way that you could fit that i suppose would fibreglass some brackets inside the hollow to enable it to bolt through your bonnet. But is it actually solid where the vent part is, and no cut out, if so launch it mate. Totally chav otherwise. I still think chopping into the bonnet for custom ventage is the way forward. Ive got my drills and angle grinders ready Quote Link to comment Share on other sites More sharing options...
DSK Posted June 22, 2009 Share Posted June 22, 2009 Thats a horrid thing! how can anyone even sell that! Its even a hollow intake, with no actual holes to act like a vent! I'd say stick it on ebay for what it is and aim for the Chav market, I bet you'll double your money or even advertise it on that barryboys site. Quote Link to comment Share on other sites More sharing options...
Dave Posted June 22, 2009 Share Posted June 22, 2009 Raven, if you are just wanting the scoop without all the other fittings, mesh, seals, undertray, etc. then I can supply a genuine Toyota one a lot cheaper than that. Pm if you want details. nick you have another PM -------- dave Quote Link to comment Share on other sites More sharing options...
mwilkinson Posted June 22, 2009 Share Posted June 22, 2009 Wont installing a nasty UK spec scoop devalue the car Quote Link to comment Share on other sites More sharing options...
Al Massey Posted June 22, 2009 Share Posted June 22, 2009 Would you cut a hole in your bonnet as well then? Why not? I cut into mine to put in a vent. Yeah i would, as was quite happy to. If i dont get any joy with this i will cut my own custom vent in the stock bonnet Go for it. I did on mine and im more than happy with it Quote Link to comment Share on other sites More sharing options...
The Raven Posted June 22, 2009 Author Share Posted June 22, 2009 The only way that you could fit that i suppose would fibreglass some brackets inside the hollow to enable it to bolt through your bonnet. But is it actually solid where the vent part is, and no cut out, if so launch it mate. Totally chav otherwise. I still think chopping into the bonnet for custom ventage is the way forward. Ive got my drills and angle grinders ready LMAO. Ok ok thats it! When yours is fixed i say we cut my bonnet! If it works then all the better if not...........well im sure it will work out just fine. I keep looking at it time and time again those vents down the side need doing. Well worse case is i would need a new bonnet....... Quote Link to comment Share on other sites More sharing options...
themodifiedkid Posted June 22, 2009 Share Posted June 22, 2009 Yep defo up for that, might end up up doing mine at the same time. Well what i mean is see how yours turns out first then attack mine Quote Link to comment Share on other sites More sharing options...
The Raven Posted June 22, 2009 Author Share Posted June 22, 2009 Yep defo up for that, might end up up doing mine at the same time. Well what i mean is see how yours turns out first then attack mine I KNEW IT, cut mine to bits then if it turns out ok do yours:sly: Sod bag Quote Link to comment Share on other sites More sharing options...
themodifiedkid Posted June 22, 2009 Share Posted June 22, 2009 Its called be clever LOL REmember "he who dares.............................................wins" Quote Link to comment Share on other sites More sharing options...
The Raven Posted June 22, 2009 Author Share Posted June 22, 2009 Its called be clever LOL REmember "he who dares.............................................wins" Do i have to remind you about my dash? or tinting? To all you wanting this one of a kind bonnet vent i am willing to sell it............or swap for a TRD spoiler......... Quote Link to comment Share on other sites More sharing options...
themodifiedkid Posted June 22, 2009 Share Posted June 22, 2009 Do i have to remind you about my dash? or tinting? To all you wanting this one of a kind bonnet vent i am willing to sell it............or swap for a TRD spoiler......... Well worth that, altho id be wanting some cash on top aswell. Remember that is a top quality vent:blink: Quote Link to comment Share on other sites More sharing options...
