Guest avaasdf Posted November 21, 2008 Share Posted November 21, 2008 (edited) Hi, im new on this forum and im getting my supra deliverd i 3 weeks sadly its imported on some retarded norwegian rules so its not allowed to tune it. Therefore i was woundering if i could do something "invisible" electronict, pistons ore something like that Thanx from a soon to be supra owner btw im thinking about using from 2000 to 10.000 $ Edited November 21, 2008 by avaasdf (see edit history) Quote Link to comment Share on other sites More sharing options...
Lbm Posted November 21, 2008 Share Posted November 21, 2008 There's probably not a lot you can do to make a significant difference. Any reason why you didn't by a tt, looking at your modification budget? Quote Link to comment Share on other sites More sharing options...
stevie_b Posted November 21, 2008 Share Posted November 21, 2008 Your options are very limited with an NA. It's been discussed a lot already. Decat is the main thing that springs to mind, but that probably doesn't count as "invisible". Quote Link to comment Share on other sites More sharing options...
hoff Posted November 21, 2008 Share Posted November 21, 2008 OEM air box and filter, Tubular manifold, uprated exhaust, good service, and thats about it really mate. NA-TT conversions are popular though. But you're looking at between £2-3K. Quote Link to comment Share on other sites More sharing options...
Guest avaasdf Posted November 21, 2008 Share Posted November 21, 2008 the tt costs 25.000$ more, an are very har to register in norway :\ what is a decat? Quote Link to comment Share on other sites More sharing options...
hoff Posted November 21, 2008 Share Posted November 21, 2008 click on...decat:) Quote Link to comment Share on other sites More sharing options...
Guest avaasdf Posted November 21, 2008 Share Posted November 21, 2008 ah btw, is there a chip in a na supra? Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted November 21, 2008 Share Posted November 21, 2008 The ECU is not chipable outside Japan and Canada, there is also nothing to be gained by doing this to the N/A ECU, you are pretty much stuck for anything that is not immediately apparent for tuning the N/A, sorry! Quote Link to comment Share on other sites More sharing options...
Guest sundog Posted November 21, 2008 Share Posted November 21, 2008 A N/A owner recently told me he was sure that the splitfire full leads set up made a lot of difference to the power of he's car,didnt have anything to back that up with though any ideas on this? Sundog Quote Link to comment Share on other sites More sharing options...
Kranz Posted November 21, 2008 Share Posted November 21, 2008 Splitfire leads will do nothing.... not one jot, except empty your wallet! If you have faulty leads then replace them with a stock set. You'll get a power gain if faulty leads are replaced, but that's all. Quote Link to comment Share on other sites More sharing options...
Kranz Posted November 21, 2008 Share Posted November 21, 2008 what is a decat? If you want an invisible decat then get a second set of catalysts and drill/bash the insides out so that they are empty but look like they are still fitted. If you really want to get all the power gain then you could sleeve them inside with a tube to prevent power loss. Quote Link to comment Share on other sites More sharing options...
3LL Posted November 21, 2008 Share Posted November 21, 2008 rather than tuning engine, why not look at improving brakes, and suspension. He who brakes later, and goes faster round corners, goes faster in general Quote Link to comment Share on other sites More sharing options...
hoff Posted November 21, 2008 Share Posted November 21, 2008 rather than tuning engine, why not look at improving brakes, and suspension. He who brakes later, and goes faster round corners, goes faster in general A good point and one which is often taken:) Quote Link to comment Share on other sites More sharing options...
miko_supra Posted November 21, 2008 Share Posted November 21, 2008 I've heard you get get around 40bhp with uprated cams. Although i know nothing of the subject...Might be worth researching about Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted November 21, 2008 Share Posted November 21, 2008 I've heard you get get around 40bhp with uprated cams. Although i know nothing of the subject...Might be worth researching about You're thinking of an already BPU+ or single turbo Supra, 40 bhp is really the upper limit with cams, on an N/A you will be lucky to see 7-10 bhp. Quote Link to comment Share on other sites More sharing options...
Kranz Posted November 21, 2008 Share Posted November 21, 2008 on an N/A you will be lucky to see 7-10 bhp. But 7 to 10 bhp on an NA is a hell of an increase Quote Link to comment Share on other sites More sharing options...
SpeedyAndy Posted November 21, 2008 Share Posted November 21, 2008 Your options are very limited with an NA. It's been discussed a lot already. Decat is the main thing that springs to mind, but that probably doesn't count as "invisible". i was just wondering would any recommend removing both cat's ? just my mate had the second cat ( back cat ) removed and seem more power from the car and proved from the Rolling road 225bhp. but then he had the first cat removed ( front cat ) and seemed a bit more nipper but when it came to the rolling road it proved with the first cat of his lost BHP - 214bhp, but gained on torque though. Would any one give any advise on this ? or maybe could explain it more ? as i'm running Full SS exhaust with the front car still on. but thinking about taking my front cat off but not to sure, Quote Link to comment Share on other sites More sharing options...
supra_aero Posted November 22, 2008 Share Posted November 22, 2008 (edited) But 7 to 10 bhp on an NA is a hell of an increase I reluctantly found that very funny Edited November 22, 2008 by supra_aero (see edit history) Quote Link to comment Share on other sites More sharing options...
mikeyb10supra Posted November 22, 2008 Share Posted November 22, 2008 The ECU is not chipable outside Japan and Canada, there is also nothing to be gained by doing this to the N/A ECU, you are pretty much stuck for anything that is not immediately apparent for tuning the N/A, sorry! Quote Link to comment Share on other sites More sharing options...
SupraAyf Posted November 22, 2008 Share Posted November 22, 2008 The easiest (and cheapest) method of getting better acceleration from your NA is to drop it off a cliff. The 0-60 is increased by 50% so you can't tell me that's a bad increase for £0 expenditure:innocent: Quote Link to comment Share on other sites More sharing options...
Dazzi Posted November 22, 2008 Share Posted November 22, 2008 The easiest (and cheapest) method of getting better acceleration from your NA is to drop it off a cliff. The 0-60 is increased by 50% so you can't tell me that's a bad increase for £0 expenditure:innocent: Smart comment Quote Link to comment Share on other sites More sharing options...
3LL Posted November 22, 2008 Share Posted November 22, 2008 The easiest (and cheapest) method of getting better acceleration from your NA is to drop it off a cliff. The 0-60 is increased by 50% so you can't tell me that's a bad increase for £0 expenditure:innocent: Would the same thinking not apply to a TT then, or any other car for that matter, if thats the easiest and cheapest way of making your car go faster? Quote Link to comment Share on other sites More sharing options...
Dazzi Posted November 22, 2008 Share Posted November 22, 2008 Not cheaper in the long run if you have to buy a supra every time you want to increase your speed by '50%'. Quote Link to comment Share on other sites More sharing options...
Lbm Posted November 22, 2008 Share Posted November 22, 2008 (edited) The easiest (and cheapest) method of getting better acceleration from your NA is to drop it off a cliff. The 0-60 is increased by 50% so you can't tell me that's a bad increase for £0 expenditure:innocent: I've got a feeling that in a similar scenario, a tt would be quickest! Edited November 22, 2008 by Lbm (see edit history) Quote Link to comment Share on other sites More sharing options...
