supraGZaerotop Posted October 8, 2008 Share Posted October 8, 2008 I just had a major leaky stock bov. couldn't hear it till I set it to vent to atmosphere. now removed altogether and have full boost again . so now you have no bov? Link to comment Share on other sites More sharing options...
supraGZaerotop Posted October 8, 2008 Share Posted October 8, 2008 Best value BOV is two rubber 19mm caps a length of 4mm vaccum line and a screw in the end where exactly do you get these from? Link to comment Share on other sites More sharing options...
Robzki Posted October 8, 2008 Author Share Posted October 8, 2008 yep no bov fitted. A lot of people run like it as they say there is no need for them. And that the turbo stall/broken turbo is a myth. Ask chris wilson . Mine is only temp tho' , i'm on the lookout for a bov. But think l33 may have me sorted this weekend Posted via Mobile Device Link to comment Share on other sites More sharing options...
supraGZaerotop Posted October 8, 2008 Share Posted October 8, 2008 do you get loads of turbo flutter? Link to comment Share on other sites More sharing options...
Robzki Posted October 8, 2008 Author Share Posted October 8, 2008 not that i can hear. Its all stock tho. Not driven like a loony to try and make it stall Posted via Mobile Device Link to comment Share on other sites More sharing options...
supraGZaerotop Posted October 8, 2008 Share Posted October 8, 2008 i had a sard fitted to my silvia a while back, i use to pull the vacuum off the bov and have the flutter for a change every now and then. i always prefered the flutter sound but it used to make my nissan overfuel a bit, great with the bov fitted, the supe should be ok tho as it dont run air flow meters. Link to comment Share on other sites More sharing options...
Kirk Posted October 8, 2008 Share Posted October 8, 2008 the supe should be ok tho as it dont run air flow meters. Depends whether its jap or UK spec, UKs use MAF while japs use MAP Posted via Mobile Device Link to comment Share on other sites More sharing options...
Homer Posted October 8, 2008 Share Posted October 8, 2008 Depends whether its jap or UK spec, UKs use MAF while japs use MAP Posted via Mobile Device VVTi's also have a MAF sensor Link to comment Share on other sites More sharing options...
Kirk Posted October 8, 2008 Share Posted October 8, 2008 Ah yes I forgot bout that! Thanking you homer! Posted via Mobile Device Link to comment Share on other sites More sharing options...
