Abbreviations you'll see being used on this board
Aerotop Dave
 Share
New alphabetical version (posted 02 Sept) if a Mod wants to delete all the guff and just leave this post.
Newer version posted 07 Sept with common interweb terms removed - it's now purely a Supra abbreviation guide
All replies (and this text) can be removed :thumbs:
AFR - Air Fuel Ratio
BHP - Brake horse power
BOV - Blow-off valve
BPU - Basic performance upgrade
DAT/File - RLTC settings file
EBC - Electronic Boost Controller
EBV - Exhaust Bypass Valve
ECU - Electronic Control Unit
EGCV - Exhaust Gas Control Valve
EGR - Exhaust Gas Recirculation
EGT - Exhaust Gas Temp
EMS - Engine Management System
EPC - Electronic Parts Catalogue
EWG - External Waste gate
ETTC - Electronic True Twin Conversion
FCD - fuel cut defender
FMIC - Front mount intercooler
FPR - Fuel Pressure Regulator
HIDS - High intensity discharge lighting
IACV - Idle Air Control Valve
IC - Intercooler
Import - The Japanese import version of the Supra
Jap spec - The Japanese import version of the Supra
JDM - Japanese domestic market
J-Spec - The Japanese import version of the Supra
Lepton - undefined (for legal purposes) numeric value for measuring speed, as in 'I was doing 45 leptons in a 30mph limit'
LSD - Limited Slip Differential
MAF meter - Mass Air Flow meter
MAP sensor - Manifold Absolute Pressure sensor
MAT sensor - Manifold Air Temperature sensor
MOD - Modification of car from standard
N/A - Normally Aspirated
NA - Normally Aspirated
NA-T - single-turbo'd NA engine.
RLTC - Racelogic Traction Control
RWHP - Rear wheel horse power
Single - Removing both stock turbos and fitting one big turbo instead (not really an abbreviation but useful to know)
SLD - Speed limit defender
SLD - Speed limit defenser
SMIC - Side-mount intercooler
STTS - Sequential Twin-Turbo Setup
Targa - Incorrect and just plain wrong misnaming of the Aerotop version
TC - Traction control
TPS - Throttle Postition Sensor
TRAC/File - RLTC settings file
TT - Twin Turbo
TT6 - Twin Turbo, 6 Speed manual
TTC - True Twin Conversion
TVD - Torsional Vibration Damper (a.k.a. front crank pulley)
UK - The UK version of the Supra
VVTi - Variable Valve Timing intelligent
WI - Water Injection
IC - Intercooler
J-Spec - The Japanese import ver... you get the idea
SMIC - Side-mount intercooler (the stock unit in other words)
TT - Twin Turbo
VVT-i - Variable Valve Timing - intelligent
  • 1 month later...
  • 1 month later...
Oh. Too late now, I've put them in.
Shall I take them out?
Up to you really Dave, you're the Mod. Thing is, there's eleventy zillion internet abbreviations and plenty of other sites that already cater for translating them.
We could list them all but it seems a bit redundant to me. Your call though mate, I don't mind either way.
This the Supra - Technical - FAQ though . . .
:thumbs:
-Ian
 Share
