Steering problem.
Kendo11
 Share
Have a bit of a concerning steering issue at the moment.
Getting a lot of feedback through the wheel at about 60mph+ and doesn't go if I try to drive on through it. Vibration actually remains all the way back down to low speed.
Veering slightly to the left & feeling a bit of resistance & more vibration when turning to the right (which makes me think it's mechanical).
Had all wheels tracked & balanced recently & rubber is in ok condition.
Pump, rack etc?
Had the car on a ramp and checked for play in the wheel bearings and bushes?
Grab the wheel at 12 and 6 position and check for play.
Same at 3 and 9 o clock.
Pull down on control arms and drop links etc to see for any play knocks.
Eliminating that could just just be a sticky calliper or warped disc
  • 3 weeks later...
Well by process of elimination and throwing time and money at it I think I'm heading down the route of needing a new CV joint or shaft.
Going into a garage this week for more analysis and hopefully a fix.
If steering wheel is shaking, it's mostly to do with the front, so doubt it'll be a cv joint. I have the same issues and i'm thinking it's a balljoint.
So far replaced everything apart from the hubs and control arms. Waiting for a front lower arm and then my front will have been redone.
  • 5 weeks later...
 Share
