Poly bushes
Rookey
 Share
Major retrograde step, and without a lathe to make mandrels to push the old bushes out and the new ones in it will be a PITA with the risk of damage. The science that went into the stock bushes and uniballs is not trivial, they are complex and clever things. If Toyota thought some plain polyurethane bushes were as good or better they sure as hell would have used them. Suspension bushes are one of the hardest worked parts of a car, and even over the last 15 / 20 years technology has come on apace. Buy new arms!
EDIT : There are very specialised cases that favour different or uniball bushes, usually for racing or drag racing. You need to know exactly what you are doing though, it's remarkably easy to lock up suspension movement and cause huge stresses, damage or breakage if done incorrectly. When polyurethane bushes first came out one application was rear axle mounting rods for Chevettes and the Opel Kadett equivalent, popular for rallying, racing and general modifying. The stock bush was a voided bush to allow the rod to rotate in a controlled way when the axle articulated in roll. The poly ones resisted this, very strongly. The floor pans where the bodyshell end of the rods mounted saw huge loads and eventually cracked and failed.
Rear upper suspension arm £430 inc vat each
Lower suspension arm No 1 which has and eccentric adjuster to alter the toe £142 inc vat each
Lower suspension arm No 2 which has and eccentric adjuster to alter the camber £227 inc vat each
Those are retail prices and you should be able to get decent discount off them depending who you use
I can get the rear upper arm for under £350 inc vat
Theres also a strut rod but i've not got a price on that.
pollybushes all the way lol
I'm guessing you mean the Right Foot here. Well, those are not the ones that scare me. That's up to the driver not to do that. I've just heard several accounts on the supra loosing the rear out of a round about without any real throttle or wet road. It's those that scare me. I usually just file them under the "buf-of-cause-you-didn't-do-anything-wrong-while-crossing-my-fingers" category. Your post above just made me think and *definatly* off the thoughts of changing to poly bushes (which probably weren't going to happen anyway as I can't find anyone that I trust that would do the apparently horrible job)
I've never used their parts but they list a 3 year warranty on all parts which you don't get
off Toyota !!
You need to find a Blue Print parts outlet or you need to be a wholesale outlet or garage
to buy direct from them
My local motor factors supplies blue print parts. I used them for arms for my prelude and they were pretty good, just wanted to know if they were comparable to replacing with toyota parts.
Edited by bigbloodyturbo (see edit history)
  • 5 months later...
Sorry to bring this back to life, but has anyone actually tried to control arms from rockauto.com? They're supposedly pattern parts including bushings and ball joint at a 3rd of the cost. A wild guess would say that the Toyota items are the price they are for a reason, but then there's the feeling that OEM parts are just massively overpriced. Anyone shed any light on this?
 Share
