Blue Dash Issues!
squiffy
high i have my dash in pieces at the mo getin rid of the walnut effect siht the previous owner decided to stick over it.
i have seen a few cars on the web with blue dash lights, is there a kit on sale or what? looked but cant find one. thought as i have it out anyway may as well try and sort it
cheers
No Emin's been cool, it was just that he used the wrong size LED in the driver's door switch so now the window won't auto-down! but he said he'll fix it but would prefer to meet me somewhere (I don't want to ask him to come all the way here for 1 LED!!!).
Mine too! Perhaps we can arrange a "change my door LED meet"? LOL
I would happily recommend Emin, he's a top bloke. I've not had any dealings with Heckler, but his kit looks good too.
So there you go, two possible routes for you!
Best of luck.
oh dear, sounds like a couple were not 100% pleased (mike, I thought you were well chuffed with yours?!?)
No real complaints at all, Emin did a top job at my home on a cold day - everything was spot on and has been for a while.
Over time bits stopped working or went erratic - probably due to my continued removal of dash panels to mess with other things. I spoke to Emin who said he'd come back and look at it for me but we never seemed to get anything organised.
In the end I sorted it all on an exchange basis with Heckler, it was easier for me at the time and I wanted to move from the EL wire solution and go all LED. If I'd have chased him I'm sure Emin would have sorted me out, he's a good guy.
Use Heckler or Emin, you'll be happy with either.
I did my own following Hecklers instructions - made a few enhancements of my own - mostly involving red LEDs for the front/rear demister buttons and a four cluster LED set for the dial backligting, still got "dim" spots, but overall I'm happy - if I ever get enough spare time I will finish of the ciggy lighter/ignition/door key/window etc
See attached pic - Yum :D
I had Simon (Heckler) come back twice to sort out the brightness of the LEDs as I'm a picky bugger, and he did quite cheerfully. The only prob I have had is the light behind the aircon buttons has stopped working because the regulator thingy died. Simon doesn't use them any more because of the failure rate and will fix mine whenever he and I both get a chance to meet up :)
-Ian
-Ian
Oh GOD look at that mish mash of colours!!! :twak:
-Ian
Yes... I will... 4 weeks time ;)
  • 1 year later...
I did my own, but seem to have a problem when I turn the lights on..! All looks great with the lights off, turn them on and a few of the LED's that did work then dont..! :(
I have the exact same problem... Did you manage to fix this? If so how?
-Ian
That looks fantastic to me!!
How much does Heckler charge for such a job. i realise I am a fair distance away but I will travel to have a job done well!!
H.
I travelled all the way up to Heckler in Marham to get my done H. That's 2 1/2 hours away because it was a little bit cheaper (not with petrol costs though! :)) but mainly it was a chance to meet Si and have a break in the sun while he did all the work ;)
Nothing for me to do. IIRC, he charged me around £125 fitted....but that included fitting my metal monkey dials too. :)
