stevie_b Posted December 19, 2005 Share Posted December 19, 2005 My manual NA can be difficult to get into gear when cold (especially 1st and 2nd gear). After a couple of minutes of driving, it gets much easier. It's been like this for as long as I've had the car (1 year). The clutch doesn't slip though, I've tested that. Is this a common problem? If so, is there a remedy, or is it just a "feature" of the W58 'box? Thanks, Steve Link to comment Share on other sites More sharing options...
Supragal Posted December 19, 2005 Share Posted December 19, 2005 It's true of the TT's for sure. Link to comment Share on other sites More sharing options...
Ian C Posted December 19, 2005 Share Posted December 19, 2005 A nice fluid change in the 'box would help, apart from that enjoy your tough-but-agricultural gears -Ian Link to comment Share on other sites More sharing options...
Chris Wilson Posted December 19, 2005 Share Posted December 19, 2005 Clutch isn't freeing fully (clutch drag), it may adjust, it may need replacing... I can do this if you want, not far from Stoke, which is where I am assuming you are based? Link to comment Share on other sites More sharing options...
stevie_b Posted December 19, 2005 Author Share Posted December 19, 2005 Clutch isn't freeing fully (clutch drag), it may adjust, it may need replacing... I can do this if you want, not far from Stoke, which is where I am assuming you are based? Thanks Chris, but I'm based in Basingstoke, Hants. Good info though! Link to comment Share on other sites More sharing options...
