SIMON LC Posted August 6, 2023 Share Posted August 6, 2023 Currently doing a GE VVTI build and obviously changing the conrods. Just wondered what rods people are using and recommend. Probably go for secondhand GTE Rods but wondered if anybody recommended anything else? Link to comment Share on other sites More sharing options...
Style Posted August 7, 2023 Share Posted August 7, 2023 Depends entirely on your goals and budget really. If you're happy with GTE rods then a set of Eagles or something like that would be fine too. I've heard Maxspeeding ones are ok too but I don't know much about them Link to comment Share on other sites More sharing options...
AC93 Posted August 10, 2023 Share Posted August 10, 2023 I used Manley, fit and forget for upto 1000hp But if you have no intention of going above 5/600 then a healthy set of GTE ones with new rings/bearings will be fine 1 Link to comment Share on other sites More sharing options...
Noz Posted August 14, 2023 Share Posted August 14, 2023 If you're doing 600hp, then don't even change them. My GE rods are just fine at over 600hp. Get new, they aren't that expensive. A piston rod combo isn't going to break the bank. It's the labour cost in engine building that's the expensive part. Link to comment Share on other sites More sharing options...
AC93 Posted August 15, 2023 Share Posted August 15, 2023 9 hours ago, Noz said: If you're doing 600hp, then don't even change them. My GE rods are just fine at over 600hp. Get new, they aren't that expensive. A piston rod combo isn't going to break the bank. It's the labour cost in engine building that's the expensive part. He's GE VVTi so will have the weaker rods, he'll need GTE one or GE non vvti if he's adding boooooost Link to comment Share on other sites More sharing options...
SIMON LC Posted August 27, 2023 Author Share Posted August 27, 2023 GTE rods located and purchased Link to comment Share on other sites More sharing options...
Mike2JZ Posted September 5, 2023 Share Posted September 5, 2023 On 8/7/2023 at 5:29 PM, Style said: Depends entirely on your goals and budget really. If you're happy with GTE rods then a set of Eagles or something like that would be fine too. I've heard Maxspeeding ones are ok too but I don't know much about them Avoid maxspeeding; awful Chinese crap with bad machining and tolerances. Rather a used set of GTE rods any day of the week 4 Link to comment Share on other sites More sharing options...
Swampy442 Posted September 5, 2023 Share Posted September 5, 2023 If theyre coil overs are anything to go by, Maxpedorods will be garbage 1 Link to comment Share on other sites More sharing options...
