Whifbitz Intake Manifold install help required
Supra2jze
 Share
Hi there,
Just need some help with installation, myself & mechanic will be fitting the Whifbitz Inlet Manifold (Drive by wire)
1. Does the power steering need to be moved in order for clearance?
I have seen PHR steering resouvier kits but as nice as they are they seem very dear just to clear a throttle body! Is there any other ways around it / alternatives?
2. Appears to be 4 pipes on the new Whifbitz inlet manifold, but only 2 wires from the Supra that come from the top that appear to be too short to connect with the new manifold ?
3. Finally, the stock inlet has mounting points for the wiring loom. However, the new Whifbitz inlet has no mounting points for the wiring loom, is this OK to tuck under?
Thanks
I haven't got the Whifbitz manifold but have the SSI and they are all the same more or less, i had to buy PHR relocation kit but for mine and also there is no mounting points for wire loom so i have just tucked mine under the manifold. The other points cant help with as GE and haven/t gone drive by wire route yet
  • 4 months later...
  • 2 weeks later...
 Share
