Installing Oil Feed & Return
Guest d-_-b
 Share
Thanks to Fosta for this information
(Taken from his NA-T install thread)
Installing Oil Feed:
This is the Union Bolt:
If engine is still in the car, then it can be removed using a long bar and a ?mm socket:
Lexus union Bolt:
Part no: 90401-19008
  • 2 weeks later...
  • 2 weeks later...
Just to add. Whilst on the subject of the drain I may have found an alternative method , it still requires drilling but you can do this with ethe sump and engine still in the car . I know it steps away from the tried and tested method but I will keep you posted and update my build thread with pics. I am not being lazy but merely trying to find alternative methods to the same problem we get time and time again with na-t builds that and I am sure toyotas method is not the only solution. It still uses an oil return direct into the sump above the oil level.
  • 1 year later...
 Share
