Mike2JZ Posted September 17, 2019 Share Posted September 17, 2019 (edited) Engine Type - NA-T Engine Spec - Stock GE, TTHG, ARP Headstuds, 550 Siemens Injector, Whifbitz NA-T Kit, SRD Intercooler, TT Inlet Manifold welded to NA runners. Turbo - BW360 0.88 A/R Fuel Used - Shell Vpower Exhaust - 3'' Transmission - R154 & A01A ECU - Link Mapped By - SRD Dyno Used - SRD Power figure - 450hp @ wheels (~530bhp) Torque figure - 450 ft.lbs @ wheels (~530 ft.lbs fly} Boost Pressure - 1.3 Bar (11.5 AFR) [~80% injector duty] Not my supra, friend of mine who's not on the forum. Results from Whifbitz kit are pretty good though, thought some of the NA-T guys may be interested in what it could achieve. IIRC 1.3 was on the limit of the distributor, anything more would cause misfire so will need coil conversion for more boost. Wastegate Pressure (0.8 bar) 1.3 Bar Comparison Edited September 17, 2019 by Mike2JZ (see edit history) Link to comment Share on other sites More sharing options...
Style Posted September 17, 2019 Share Posted September 17, 2019 Good numbers there. Was the ignition system all new components? I’ve heard of dizzy NA-T’s going into the 500’s but I sometimes wonder if that’s just down to different dynos Link to comment Share on other sites More sharing options...
Mike2JZ Posted September 17, 2019 Author Share Posted September 17, 2019 Good numbers there. Was the ignition system all new components? I’ve heard of dizzy NA-T’s going into the 500’s but I sometimes wonder if that’s just down to different dynos Don't think the ignition system was especially new, just stock leads as well. Put some new NGK BKR8E plugs in before mapping, but had to drop gap to 0.6mm to avoid miss at 1.3 bar. Perhaps with new rotor and beefier leads it would allow for more boost, but prefer the coil route as it allows for per cylinder control due to direct spark. Link to comment Share on other sites More sharing options...
AC93 Posted September 17, 2019 Share Posted September 17, 2019 You can get the HKS ignition amplifier and run all the horsepower you want ...but I'm going bolting a vvt-i head on my non-vvti bottom end, coil on plug and better spool for the turboooooo Link to comment Share on other sites More sharing options...
David P Posted September 17, 2019 Share Posted September 17, 2019 Good numbers there. Was the ignition system all new components? I’ve heard of dizzy NA-T’s going into the 500’s but I sometimes wonder if that’s just down to different dynos It's not so much the distributor, it's the 10:1 compression that restricts boost to 1.3bar max before pre-ignition becomes a problem. For more than 450ish bhpftlb, fitting a GTE headgasket drops the GE compression to 9:1 and which then allows more boost. Link to comment Share on other sites More sharing options...
Style Posted September 18, 2019 Share Posted September 18, 2019 (edited) Don't think the ignition system was especially new, just stock leads as well. Put some new NGK BKR8E plugs in before mapping, but had to drop gap to 0.6mm to avoid miss at 1.3 bar. Perhaps with new rotor and beefier leads it would allow for more boost, but prefer the coil route as it allows for per cylinder control due to direct spark. Even at 1bar I was running into issues every now and again so it's good to know you guys have managed to push it a little further than that. I've just gone CoP on mine and didn't realise how straight forward it was. Wish I'd done it years ago It's not so much the distributor, it's the 10:1 compression that restricts boost to 1.3bar max before pre-ignition becomes a problem. For more than 450ish bhpftlb, fitting a GTE headgasket drops the GE compression to 9:1 and which then allows more boost. It's already got a GTE headgasket installed. Edited September 18, 2019 by Style (see edit history) Link to comment Share on other sites More sharing options...
sidewaysdan Posted September 18, 2019 Share Posted September 18, 2019 Did you do the cop yourself mate ? Was looking to do the same on mine Link to comment Share on other sites More sharing options...
Noz Posted September 18, 2019 Share Posted September 18, 2019 Good numbers there. Was the ignition system all new components? I’ve heard of dizzy NA-T’s going into the 500’s but I sometimes wonder if that’s just down to different dynos . I ran 501hp with the dizzy without any issues. On dynojet. I'm certain it would have done more easy enough. Went cold though to save myself the pain. Link to comment Share on other sites More sharing options...
Noz Posted September 18, 2019 Share Posted September 18, 2019 Did you do the cop yourself mate ? Was looking to do the same on mine All depends on what ecu you have. If you go standalone itll be easier. So much easier. Link to comment Share on other sites More sharing options...
Style Posted September 18, 2019 Share Posted September 18, 2019 Did you do the cop yourself mate ? Was looking to do the same on mine I sourced and fitted the parts but it's being wired in at the moment by someone who knows what they're doing as I'm hopeless at that stuff. I picked up 2JZ-GE VVTi coil packs, a Toyota DH61 igniter, TT oil pump, TT crank trigger, 2 TT crank sensors and a plug for the hole that the distributor goes into. I used a bracket and custom cam gears for the cam signal but you can easy just weld the cam sensor onto the cam covers like this guy has done. https://www.supraforums.com/threads/how-to-go-distributorless-with-tt-sensors.571928/ Link to comment Share on other sites More sharing options...
Mike2JZ Posted September 18, 2019 Author Share Posted September 18, 2019 . I ran 501hp with the dizzy without any issues. On dynojet. I'm certain it would have done more easy enough. Went cold though to save myself the pain. Can you post graph. Be good to get some other NA-T's on dizzy on the forum for other people's reference. Link to comment Share on other sites More sharing options...
Noz Posted September 21, 2019 Share Posted September 21, 2019 Can you post graph. Be good to get some other NA-T's on dizzy on the forum for other people's reference. Dont have a graph sadly mate with the 501hp. Was only testing to see if there were any boost issues with the exhaust manifold. The coil conversion that we did using Syvecs was relatively straight forward. Using Audi R8 coils. I'm sure many US boys have got higher hp values with the dizzy. I can recall seeing various values over the years. I still retain the dizzy gear mechanism for cam position, so if I go cams itll be quite the opportunity as I haven't seen anyone on any forums use the BC pre vvti cams yet on a build. Link to comment Share on other sites More sharing options...
