any BT engineers on here
peter richards
right update did the test by the router , results were 60.2 and 16.4. took the plugs out and put back in and just done a test and its 57.2 and 16.4. so what would you say the reason it had got so slow , and now the fastest its been , confusing. going to try wifi , and see what that gives but if it can stay at that speed then ill be happy with it
The mains plugs are very very patchy, it will 100% be the reason for your slowness.
Anything in your house could be affecting the speed, a dodgy tv or other appliance.
Usually best practice with homeplugs is that ALL extensions on your house should be surge protected and the home plug should only ever be plugged directly into the wall.
Also depends if the wiring is on the same ring. usually upstairs and downstairs are separate so can be poorer performing
Because over the mains wiring IP stuff is fickle and can be affected by umpteen outside sources. It's crap, bin it and run some proper CAT5 cabling. It'll slow down again. If you get the range and through speed from WiFi it'll be more reliable than over the mains stuff, but still hard wiring is King!
forget the internet over the mains crap
I rather like my network over mains as the only other option to jump buildings was a wifi bridge. Its a lot easier to set up a mains adapter network than it would be to fit masts, filters and bridges. In one building though, I'd certainly stick with wired Ethernet or wifi across the network if that is possible. Never liked range extenders though as I found they could drop out of reception and then needed rebooting which always meant physically attending the extender to power off and then back on.
