Annabella Posted December 23, 2017 Share Posted December 23, 2017 Peter is ordering a 20-30m network cable to test, without the mains, to isolate the problem. - - - Updated - - - What speeds now the homeplug is in mains socket? Link to comment Share on other sites More sharing options...
Chris Wilson Posted December 23, 2017 Share Posted December 23, 2017 Can't he just put the PC by the router with a short cable as a test? Link to comment Share on other sites More sharing options...
peter richards Posted December 23, 2017 Author Share Posted December 23, 2017 speeds are the same as before on or about 20 , been out all day so will try that later, ill borrow a laptop to try it at the hub Link to comment Share on other sites More sharing options...
peter richards Posted December 23, 2017 Author Share Posted December 23, 2017 right update did the test by the router , results were 60.2 and 16.4. took the plugs out and put back in and just done a test and its 57.2 and 16.4. so what would you say the reason it had got so slow , and now the fastest its been , confusing. going to try wifi , and see what that gives but if it can stay at that speed then ill be happy with it Link to comment Share on other sites More sharing options...
Ric Posted December 23, 2017 Share Posted December 23, 2017 The mains plugs are very very patchy, it will 100% be the reason for your slowness. Anything in your house could be affecting the speed, a dodgy tv or other appliance. Usually best practice with homeplugs is that ALL extensions on your house should be surge protected and the home plug should only ever be plugged directly into the wall. Also depends if the wiring is on the same ring. usually upstairs and downstairs are separate so can be poorer performing Link to comment Share on other sites More sharing options...
Chris Wilson Posted December 23, 2017 Share Posted December 23, 2017 right update did the test by the router , results were 60.2 and 16.4. took the plugs out and put back in and just done a test and its 57.2 and 16.4. so what would you say the reason it had got so slow , and now the fastest its been , confusing. going to try wifi , and see what that gives but if it can stay at that speed then ill be happy with it Because over the mains wiring IP stuff is fickle and can be affected by umpteen outside sources. It's crap, bin it and run some proper CAT5 cabling. It'll slow down again. If you get the range and through speed from WiFi it'll be more reliable than over the mains stuff, but still hard wiring is King! Link to comment Share on other sites More sharing options...
peter richards Posted December 23, 2017 Author Share Posted December 23, 2017 ok mate thanks see how it goes , as my normal speed was around 36 ish , but last week noticed it had slowed quite a lot and nothing in the house had changed . so for it to be up over 50 now , just keep fingers crossed it stays there Link to comment Share on other sites More sharing options...
peter richards Posted December 23, 2017 Author Share Posted December 23, 2017 ok chris note taken will try the wifi tomorrow and see , but to run a cable from downstairs up to here will difficult . could end in divorce as wifey wont have anything on skirtings Link to comment Share on other sites More sharing options...
peter richards Posted December 23, 2017 Author Share Posted December 23, 2017 thank you to all that helped in the thread I really appreciate your input , its always nice to know the help is here if needed . been here a long time and nothing has changed still top notch Link to comment Share on other sites More sharing options...
Chris Wilson Posted December 23, 2017 Share Posted December 23, 2017 ok chris note taken will try the wifi tomorrow and see , but to run a cable from downstairs up to here will difficult . could end in divorce as wifey wont have anything on skirtings When you want her opinion just tell her what it should be.... Link to comment Share on other sites More sharing options...
peter richards Posted December 23, 2017 Author Share Posted December 23, 2017 lol she has all the money Link to comment Share on other sites More sharing options...
Chris Wilson Posted December 23, 2017 Share Posted December 23, 2017 lol she has all the money Any deep waters near you? Link to comment Share on other sites More sharing options...
peter richards Posted December 23, 2017 Author Share Posted December 23, 2017 few nice long piers Link to comment Share on other sites More sharing options...
Annabella Posted December 23, 2017 Share Posted December 23, 2017 Heh glad you've isolated it. Fridges are the worst to interfere as I've found in the past. See how WiFi goes, otherwise it's wired and a new patio Link to comment Share on other sites More sharing options...
peter richards Posted December 23, 2017 Author Share Posted December 23, 2017 yes thank you Link to comment Share on other sites More sharing options...
Hitbox Junkie Posted December 23, 2017 Share Posted December 23, 2017 Internet over mains is temperamental as you've got power flowing and data etc if you run through a exstention cable to its effected even more. Best bet is to run a cable directly. I had a set of wall plugs and had one kill some capacitors inside it a few times in the space of a year. Link to comment Share on other sites More sharing options...
rider Posted December 23, 2017 Share Posted December 23, 2017 forget the internet over the mains crap I rather like my network over mains as the only other option to jump buildings was a wifi bridge. Its a lot easier to set up a mains adapter network than it would be to fit masts, filters and bridges. In one building though, I'd certainly stick with wired Ethernet or wifi across the network if that is possible. Never liked range extenders though as I found they could drop out of reception and then needed rebooting which always meant physically attending the extender to power off and then back on. Link to comment Share on other sites More sharing options...
