1993 black 6speed 800bhp built single
johnd-mkiv
 Share
Time has come to put this up for sale so I can expand with work, I’m not getting the time to drive And enjoy it anymore either.
Full build thread here http://www.mkivsupra.net/vbb/showthread.php?304960-Johnd-mkiv-Supra-build
Engine Specifications:
Virtual Works Racing High Compression 9.5:1 1000+HP Race engine
New block
New crank
Clevite bearings
ARP Mains
Carr Bolts
Carillo H Beam Rods
Custom JE 0.040 over Pistons/Rings 9.5:1Compresion Ratio
HKS 1.8mm head gasket
ARP head bolts
Engine balanced to 9000rpm / 8750rpm limited
HKS Thermostatic Oil cooler with custom filter relocation
Titan Motor sports dampened bottom pulley (ATI)
Gates micro V belt
New head
Ferrea 1mm OS valves
Dual Ferrea valve springs
Ferrea locators
Ferrea locks
Ferrea Ti retainers
Ported and gas flowed
HKS 280 cams
Fidanza adjustable cam pulleys
Kevlar belt
Polished covers
Custom breather system
Turbocharger & Induction:
Borg worner turbo (1000hp capable)
Blitz LM 3 row inter-cooler
Jun (clone) plenum - port matched
Bespoke short route IC pipes
AEM washable air filter
90mm Q45 Throttle Body
Fuel, Tuning & ECU:
Syvecs ecu (mapped by Ryan G and Romain)
1200cc Injectors
BL 17.4mm fuel rail, end feeds, center return
Twin fuel pumps bespoke system
Bespoke -8 and -6 fuel lines Speedflow fittings
Aeromotive Fuel Pressure Regulator & Gauge
Areomotive fuel filter
Greddy Boost Solenoid
Custom brand new engine Loom
Cooling:
Fluidyne aluminium radiator
Custom flexible ducting
Stock viscous van
Fluidyne Power assisted steering fluid cooler.
HKS wing mounted oil cooler, flexible ducting
Custom coolant dual reservoir system
Exhaust:
HKS Stainless steel heat coated tubular manifold
Tial 60mm external waste gate
65mtm waste gate - re-entry to exhaust
Wrapped and heat coated down pipe by PHR
V band clamps
Bespoke 4” stainless exhaust sytemn
Drivetrain:
Getrag V160 six speed
OS giken triple
Big case 6speed lsd
Weight Reduction & Transfer:
Battery located to the boot aswell as fuse box
Space saver removed
Suspension, Wheels, Tyres & Brakes:
fukk height and adjusterble damping coilovers
K Sport 8 pot 356mm / UK two pot + Endless pads
Brake Master Cylinder stabiliser bracket
Goodridge stainless steel brake lines
Genuine doluck double six wheels with r888 tyres
Interior & ICE:
TRD 10000 RPM Tacho
TRD Customised 240MPH Speedo
Healtech Speedohealer(Dual settings for different tire sizes) GPS calibrated speed recall
Apexi warning gauges
AEM AFR Gauge
Hydro dipped dash
Custom seats
Momo/TRD quick release
Momo Gear knob
Alpine head unit
Infinity Fronts
Focal Rears
Sony amp
Focal Sub
Exterior:
Doluck front bumper
Veilside overfenders and skirts all blended
Custom rear bumper blended
Fogs, Hi & Lo beam 6500K HID's
Face lift customised front indicators
Clear side indicators
Ford panther black full body paint
I’ve spent so many hours getting this car to what it is as it’s my pride and joy, it maxed the rollers out at 750bhp with print outs to show now with new turbo road mapped estimated 800bhp at 1.4bar with more mapping and mods higher bhp achievable
Badpoints
Front bumper needs a repair and paint (clipped a Kurb parking)
Few bits of paintwork need touching up was going to get it done around March next year in time for summer.
3rd gear synchro is going drives notmally selecting all gears fine, only when high reving you will get a grind.
It’s got an oil leak from the sump pan or turbo return.
This is an amazing car with a serious list of mods If I could keep I would but it’s time to progress in life. Full videos are on fb will upload this advert with videos onto the Supra pages shortly
Looking for £21000 Ono
 Share
