Strange noise when moving
Lewmc93
 Share
I'd say hub bearings, buy new dust caps, removing the old ones usually destroys them, Toyota only parts.
£284 for the toyota bearings, when whifbits have similar for £90 surely they cant be that much worse, dont really have 284+ labour cost to spare !, what do you mean dust caps as that to me means the screw on caps on the tire valves .
sounds terrible, definitely a bearing type noise.
You could remove the caliper and try again, just to rule that out catching.
I cant get the caliper off as they bolts are literally weld tight and even my body weight wont budge them.
CW means the hub grease cap
Just bought 2 delivered tomorrow for £85 , thank you for the tip !
Ah right, now to try find where to buy these if i need them
https://www.toyodiy.com/parts/p_J_1994_TOYOTA_SUPRA_JZA80-ALPVF_4303.html
Part numbers are same for GE and GTE, you could try calling Toyota or some of the traders on here
  • 4 weeks later...
 Share
