it's Christmas to go out and treat yourself to a big single turbo HKS Supra
KnightRider1981
it's Christmas so go out and treat yourself!
Hi guys i had to do it... as it is coming up to Christmas! all i can say is WOW going from my Ridox Na 8 weeks later to an Na-T then 4 weeks to This, it's mind blowing :D
Spc
98 2JZ-GTE VVTI
HKS TO4Z Full Turbo Kit
HKS V cam
HKS R Type intercooler kit
HKS FCON V-Pro ECU and harness
HKS fuel rail
HKS injectors 1000cc
HKS boost controller
HKS Hipermax suspension
HKS oil cooler
HKS Twin Power ignition
Brembo big front brake kit
Whiteline anti roll bars
TRD complete poly bush
Tiptronic transmission
Transmission cooler
Blitz 19" wheels
ERL water injection
Hyper Medallion exhaust [GRIN][/GRIN]
Edited by KnightRider1981 (see edit history)
The Fcon must be running piggyback off the stock ECU to control the gearbox, would be interested to see if it has a speed delimiter fitted, and if so, which one. As Frank Bullit said, these cars have a kickdown issue if driven over 120mph.
I'll have to report back to you on that when I get the opportunity...
If you peel back the passenger floor carpet, the ECU is under a black plastic tray that's held in with a couple of nuts (10mm IIRC). Your ECU wiring will probably have a 'patch lead' harness which goes between the original wiring and ECU, with wires going from that to your FCON. Somewhere these leads there should be a few wires going to a black plastic square with the letters 'SLD' (Speed Limit Defenser). This overrides the stock ECU speed limiter, which allows the car to go beyond 120mph. If it has the incorrect one fitted, the ECU will allow the gearbox to 'kick down' at an unsafe speed, potentially causing lots of nasty and expensive problems. So until you're sure, if you take the car above 120, don't do anything that would make the car 'kickdown' (IE, taking your foot off the accelerator and then putting it down hard again straight away).
thank you for taking the time to explain this to me I appreciate that! when I'm back on base I'll have a look and follow your instruction.
again much appreciated..
