ripped_fear Posted December 21, 2015 Share Posted December 21, 2015 Ok very brief question. I'm just changing the rad and overflow tank, and the water pump will be getting later next month. Am I wasting money putting new coolant in for the sake of a month. Could I just put water in for now, it wont be getting driven in freezing temps etc. Don't want to be causing corrosion etc in the new rad even if it is only for a month. Is it safe? If so I will save my new coolant I have for when the water pump is done. Link to comment Share on other sites More sharing options...
Dnk Posted December 21, 2015 Share Posted December 21, 2015 Fill with new coolant then when you change the pump just catch the coolant and put it back in Link to comment Share on other sites More sharing options...
ripped_fear Posted December 21, 2015 Author Share Posted December 21, 2015 Fill with new coolant then when you change the pump just catch the coolant and put it back in ok cheers, only issue is I have already slung the old coolant as it looked a bit past its best anyway. Link to comment Share on other sites More sharing options...
stevie_b Posted December 21, 2015 Share Posted December 21, 2015 As Dnk says though, put new fresh coolant in now. Then when it's time to change the water pump, drain it out into a clean bowl or bucket, so you can put it back in the rad when it's time to refill the system. Link to comment Share on other sites More sharing options...
Dnk Posted December 21, 2015 Share Posted December 21, 2015 As Dnk says though, put new fresh coolant in now. Then when it's time to change the water pump, drain it out into a clean bowl or bucket, so you can put it back in the rad when it's time to refill the system. Link to comment Share on other sites More sharing options...
ripped_fear Posted December 21, 2015 Author Share Posted December 21, 2015 Cheers guys will do that then Link to comment Share on other sites More sharing options...
Supraleeturbo Posted December 21, 2015 Share Posted December 21, 2015 Just don't be tight and use it now and then do new coolant in a months time lol Link to comment Share on other sites More sharing options...
ripped_fear Posted December 21, 2015 Author Share Posted December 21, 2015 Just don't be tight and use it now and then do new coolant in a months time lol Mr money bags. Yeah if needs must I will just seems pointless too if I dont have to. Will stick with the above for now anyway as I need to do the thermostat now as it seems to have stuck. Link to comment Share on other sites More sharing options...
supra_ufo Posted December 21, 2015 Share Posted December 21, 2015 I did the same, drain it into a clean bucket and pour back in Link to comment Share on other sites More sharing options...
