Stainless caliper piston and caliper seal kits for sale
Chris Wilson
 Share
  • Replies 56
Can you supply refurb kits for the Lexus ls400 front calipers ?
I can do seals no problem, from stock, pistons too, but would need a sample. If the pistons are two different sizes I would need a sample of one of each. I can return them undamaged, (or at least in the same state they arrive... ;)). PM sent.
  • 1 month later...
Thanks for the kind words. There is an "unofficial" way of helping fit the dust boots on the UK spec calipers, told to me by someone who rebuilds a hundred times more calipers than i do. It is to use a bit of Super Glue on the seals where they sit on the bodies where the round clips go over. the boots and the caliper bodies need to be totally clean and dry, like you seem to have done so well in the photos. It dries, as you probably know, in seconds, and greatly helps stop the dust boots slipping off.
The other issues is the calipers corrode and what was a true square shouldered, albeit low height, section where the seals sit becomes angled.
Looks like you took cleanliness as seriuysly as you need to for these jobs and the results look superb, thanks again, glad to have helped. Take care and all the best.
 Share
