Kendo11 Posted June 22, 2015 Share Posted June 22, 2015 Afternoon all. Can members with trial rear bumpers recommend me an exhaust please? My current japspeed one sits at an iffy angle, I've been pricing up getting it modified to fit but might also go down the route of getting a new one instead, rather than butchering a perfectly fine exhaust. I want one that doesn't sit at such an angle so that it will destroy the bumper. So what are you guys running? Link to comment Share on other sites More sharing options...
Big Mark Posted June 22, 2015 Share Posted June 22, 2015 If you want a cheap fix that works do what I did to my Mongoose system. Get a length of 5 inch diameter stainless steel tube off ebay. Get one end cut with the correct exit angle, get the other end cut to length and the angle you want, I have mine angled and then get old tip cut off and new one welded on. Helps if you have a good mate that can weld like I did. Saved me getting a new exhaust as not only did it look better but also sounded a lot better as old small exit had twin perforated tubes inside it that killed the sound. Link to comment Share on other sites More sharing options...
Kendo11 Posted June 22, 2015 Author Share Posted June 22, 2015 You mean just the tip? I could do mate but it's in pretty good condition so it's worth a little bit of money. That's definitely an option but I'd much rather just get one that fits. Link to comment Share on other sites More sharing options...
Luxluc Posted June 22, 2015 Share Posted June 22, 2015 Whifbitz 4" Ti here ..... identical to the HKS Ti. Link to comment Share on other sites More sharing options...
Kendo11 Posted June 22, 2015 Author Share Posted June 22, 2015 Whifbitz 4" Ti here ..... identical to the HKS Ti. Perfect fit? Link to comment Share on other sites More sharing options...
j_jza80 Posted June 22, 2015 Share Posted June 22, 2015 HKS superdrager would be ideal Link to comment Share on other sites More sharing options...
Big Mark Posted June 22, 2015 Share Posted June 22, 2015 You mean just the tip? I could do mate but it's in pretty good condition so it's worth a little bit of money. That's definitely an option but I'd much rather just get one that fits. Yes just the tip, plus you can cut the angle on the tube where it will be welded on the back box to exit exactly where you want and is a dam sight cheaper than a new exhaust. Tube here http://www.ebay.co.uk/itm/125mm-127mm-5-inch-x-500mm-stainless-steel-1-2-metre-tube-pipe-exhaust-repair-/121302027011?pt=LH_DefaultDomain_3&hash=item1c3e2a0b03 and I paid £10 to have then ends cut to the length/angle I wanted by a local company and my mate and I cut off the old one and welded on the new one. Link to comment Share on other sites More sharing options...
Kendo11 Posted June 22, 2015 Author Share Posted June 22, 2015 Hmm. Coul definitely be an option. Link to comment Share on other sites More sharing options...
Luxluc Posted June 22, 2015 Share Posted June 22, 2015 HKS Ti is angled, but passes the trial .. although close. Link to comment Share on other sites More sharing options...
downimpact Posted June 22, 2015 Share Posted June 22, 2015 (edited) Tanabe medallion is fine though not to everyone's volume tastes Edited June 22, 2015 by downimpact (see edit history) Link to comment Share on other sites More sharing options...
Kaan W Posted June 22, 2015 Share Posted June 22, 2015 HKS Ti 4" sits perfectly I'd say - http://www.mkivsupra.net/vbb/attachment.php?attachmentid=202539&d=1435008515 Link to comment Share on other sites More sharing options...
Kendo11 Posted June 22, 2015 Author Share Posted June 22, 2015 Appreciate the replies guys Link to comment Share on other sites More sharing options...
jazz1 Posted June 22, 2015 Share Posted June 22, 2015 HKS Ti 4" sits perfectly I'd say - http:// http://www.mkivsupra.net/vbb/attachment.php?attachmentid=202539&d=1435008515 Snap, with bit of cutting. Link to comment Share on other sites More sharing options...
j_jza80 Posted June 22, 2015 Share Posted June 22, 2015 Straight pipe suit the Trial rear better than angled IMO Link to comment Share on other sites More sharing options...
Jord Posted June 23, 2015 Share Posted June 23, 2015 While on the subject. Is anyone using or tried using a Blitz Nur Spec with a Trial rear? Link to comment Share on other sites More sharing options...
Kaan W Posted June 23, 2015 Share Posted June 23, 2015 I had a nur spec with trial rear, again angled but fitted fine. Link to comment Share on other sites More sharing options...
