ballsdeep Posted January 24, 2015 Share Posted January 24, 2015 Supra had to be rescued by my mates bmw on Friday night he will never let me forget it!! Iv had a look today and it's coming out of the little bleed pipe on the water pump, does this mean it's nackared or is something else the cause? Iv read there's a core plug near by could this be at fault?? squeezing the lower rad hose makes it trickle out of the pipe. Link to comment Share on other sites More sharing options...
Jellybean Posted January 24, 2015 Share Posted January 24, 2015 In non technical terms , Coolant comes out there to warn u you your pump is done Link to comment Share on other sites More sharing options...
ballsdeep Posted January 24, 2015 Author Share Posted January 24, 2015 So it's the pump that's failed, wonderful I see a lot of people selling used pumps are these upto the job, noticed josh has a 30k used one for sale? I'm going to need one sharpish and Toyota take for ever!! Link to comment Share on other sites More sharing options...
Jellybean Posted January 24, 2015 Share Posted January 24, 2015 New OEM I am afraid , you are wasting you time with a 2nd hand pump, they are not expensive its the labour Link to comment Share on other sites More sharing options...
pedrosixfour Posted January 24, 2015 Share Posted January 24, 2015 Blueprint do a replacement pump. If you are lucky, a decent motor factors doing that particular range may have it in stock or if not would probably have it for you next working day if you enquired before lunchtime. Can't see how Toyota could take that long to get one though, aren't the same pumps in the GS300 and probably a few more models besides. My 1JZ came with a shagged water pump fitted & a second hand unit as a replacement. I installed the engine with the bad pump simply to see if the engine was otherwise solid. Once satisfied it wasn't for the skip I clamped the spare pump standing on its nose in a vice, I filled the housing with hot coolant, then left it overnight to see if there was any coolant leaking by the shaft seals the next morning. Nothing leaked, the used pump was lorried onto the engine and has been there ever since (2011). Link to comment Share on other sites More sharing options...
ballsdeep Posted January 24, 2015 Author Share Posted January 24, 2015 I'm hoping my brother inlaws garage can source me one, I don't really want to pay Toyota prices if I can help it, seen that tbc parts do one for £67 so il be enquiring about this on Monday. Failing that I woulnt mind a blueprint one if I can find one. Link to comment Share on other sites More sharing options...
Jellybean Posted January 24, 2015 Share Posted January 24, 2015 I got a new OEM Water Pump + Housing in 2 days off Toyota for 161 Euro , just the waterpump is alot cheaper Link to comment Share on other sites More sharing options...
Rich.2211 Posted January 24, 2015 Share Posted January 24, 2015 As above, don't waste your time with a second hand one especially when TCB are selling new OEM items for £63.69 + Vat each I would probably pay the extra though and get one with the rear housing as one complete assembly as the core plug at the back of the NA water pump housings has been known to fail. Link to comment Share on other sites More sharing options...
ballsdeep Posted January 25, 2015 Author Share Posted January 25, 2015 As above, don't waste your time with a second hand one especially when TCB are selling new OEM items for £63.69 + Vat each I would probably pay the extra though and get one with the rear housing as one complete assembly as the core plug at the back of the NA water pump housings has been known to fail. On tcb website they list the same part number for 2jzgte and 2jzge so am I right in thinking it's just the rear housing that differs. Anyone have anymore links to where I can get one complete inc rear housing. Link to comment Share on other sites More sharing options...
Dazzi Posted January 25, 2015 Share Posted January 25, 2015 Importcarparts. Bought mine for around 50 quid. Been on my car a few years now Link to comment Share on other sites More sharing options...
ballsdeep Posted January 25, 2015 Author Share Posted January 25, 2015 Importcarparts. Bought mine for around 50 quid. Been on my car a few years now Cheers dazzi was that inc the rear housing? Link to comment Share on other sites More sharing options...
Dazzi Posted January 25, 2015 Share Posted January 25, 2015 Cheers dazzi was that inc the rear housing? Yes it was. Just looking now and they're only selling the turbo water pumps atm Link to comment Share on other sites More sharing options...
ballsdeep Posted January 25, 2015 Author Share Posted January 25, 2015 Thanks Iv just been on but like you said there only listed for 2jzgte and to me looks like it's without the rear housing? I'm not sure if the pumps are the same and it's the housing that is different? Link to comment Share on other sites More sharing options...
Swampy442 Posted January 25, 2015 Share Posted January 25, 2015 You already have the rear housing, you wont need to replace that. Also the same pump as a 1JZ Soarer Link to comment Share on other sites More sharing options...
ballsdeep Posted January 25, 2015 Author Share Posted January 25, 2015 You already have the rear housing, you wont need to replace that. just what I wanted to hear, makes things simpler! Will order from tcb on Monday. Now to find out where this core plug is hiding? Link to comment Share on other sites More sharing options...
Rich.2211 Posted January 25, 2015 Share Posted January 25, 2015 There is a plug on the back of the NA water pump housing that must corrode from the inside. It happened on Josh's, the water pump itself was fine but the plug had developed a hole in the center allowing coolant to leak out. Seen it a few times on here. Link to comment Share on other sites More sharing options...
MRX Posted January 25, 2015 Share Posted January 25, 2015 The core plug on the back of my pump has just gone. In the process of removing it this weekend but the crankshaft pulley is being a bugger.... Link to comment Share on other sites More sharing options...
ballsdeep Posted January 25, 2015 Author Share Posted January 25, 2015 http://www.mkivsupra.net/vbb/showthread.php?233817-Please-help!-Water-leak-from-Thermostat Going off this thread NA has a 20mm and TT 25mm core plug. Link to comment Share on other sites More sharing options...
Chris Wilson Posted January 25, 2015 Share Posted January 25, 2015 Both the pump itself, and the backing plate, are totally different between TT's and N/A's. Be *SURE* to get what you need. I may well have usable secondhand pumps, but i don't recommend you use them. Link to comment Share on other sites More sharing options...
ballsdeep Posted January 25, 2015 Author Share Posted January 25, 2015 Thanks chris but I really do want a new one! Cheers for confirming there totally different, when I speak to tcb I will make sure Im getting the right one! This makes you think they are the same! Link to comment Share on other sites More sharing options...
Chris Wilson Posted January 25, 2015 Share Posted January 25, 2015 The actual pump body bolt pattern is different, N/A versus TT. The backing plate, which *sometimes* come with a new pump, but often do not, is also quite different, N/A versus TT. I have frequently had customers bring pattern pumps for a TT, let's say, and find they are really for an N/A, and vice versa. Bit of a minefield. Link to comment Share on other sites More sharing options...
ballsdeep Posted January 27, 2015 Author Share Posted January 27, 2015 So my usual grease monkey (brother inlaw) was too busy to fit me in so his mate is doing the work, right off the bat he orders the wrong pump now he's ordered a blueprint part which is fine but is more $$$ and I'm unsure if the rear housing is included now I know from a previous thread rich.221 has used this part before so I'm just wondering what you paid?? Also apparently he's been moaning that the rear housing might be bonded on but I'm thinking he's maybe left bolts in. Anyone have a diagram I can't find one. I'd tell him to leave it but I really want the core plug changing for peace of mind! Link to comment Share on other sites More sharing options...
Rich.2211 Posted January 27, 2015 Share Posted January 27, 2015 Mine was Blueprint and came with the rear housing Link to comment Share on other sites More sharing options...
ballsdeep Posted January 27, 2015 Author Share Posted January 27, 2015 Mine was Blueprint and came with the rear housing Hopefully mine does too, I Don't suppose you remember what you paid? Link to comment Share on other sites More sharing options...
Rich.2211 Posted January 27, 2015 Share Posted January 27, 2015 Hopefully mine does too, I Don't suppose you remember what you paid? I can't remember off the top of my head but I got it at a discounted price as a good friend of mine worked at Motormania. Link to comment Share on other sites More sharing options...
