LOGIE Posted August 22, 2014 Share Posted August 22, 2014 (edited) (I meant MODIFIED tapatalk wont let me edit title) ).Weird one. When my car was an NA I was guilty of forgetting to turn the headlights or sidelights off from time to time. I would look at the car a few hours after getting home and realise ive left the sidelights on. Seems since the TT conversion my lights must time out/turn themselves off? I got in the car tonight and the sidelight stalk was in on position but lights were off. I havent been in the car for over a week. Very weird. Do TTs turn off their own lights? I can't get my head around this. Edited August 22, 2014 by LOGIE (see edit history) Quote Link to comment Share on other sites More sharing options...
Littler Posted August 22, 2014 Share Posted August 22, 2014 In my TT it was a case of if the lights were left on and the engine was off as soon as you opened the door to get out they turned off Quote Link to comment Share on other sites More sharing options...
Scott Posted August 22, 2014 Share Posted August 22, 2014 Are your sidelights working? Quote Link to comment Share on other sites More sharing options...
LOGIE Posted August 22, 2014 Author Share Posted August 22, 2014 Are your sidelights working? Yep had been left on at the stalk but actual lights were off. I checked to make sure they were working and they were. Quote Link to comment Share on other sites More sharing options...
straightsix Posted August 22, 2014 Share Posted August 22, 2014 That's gotta increase it's value! Quote Link to comment Share on other sites More sharing options...
Scott Posted August 22, 2014 Share Posted August 22, 2014 Yep had been left on at the stalk but actual lights were off. I checked to make sure they were working and they were. Come to think of it. I think my lights stay off, but the beeper to let you know they are on sounds if the keys are out and the door is open. Not 100% sure though, it's been a while Quote Link to comment Share on other sites More sharing options...
listy Posted August 22, 2014 Share Posted August 22, 2014 Come to think of it. I think my lights stay off, but the beeper to let you know they are on sounds if the keys are out and the door is open. Not 100% sure though, it's been a while Hmmmmm mine does this. Not sure if the lights turn off or not though Quote Link to comment Share on other sites More sharing options...
charlton Posted August 22, 2014 Share Posted August 22, 2014 My NA wouldn't turn the lights off when I turned the ignition off and opened the door but my TT does, did you swap the ECU as it could be that? Quote Link to comment Share on other sites More sharing options...
David P Posted August 22, 2014 Share Posted August 22, 2014 That's one of the functions of the integration relay. Quote Link to comment Share on other sites More sharing options...
LOGIE Posted August 22, 2014 Author Share Posted August 22, 2014 My NA wouldn't turn the lights off when I turned the ignition off and opened the door but my TT does, did you swap the ECU as it could be that? Yes mate I changed everything. All looms, ecus within the car. My NA was the same no headlight chime and didnt turn themselves off. TT does both now. Quote Link to comment Share on other sites More sharing options...
LOGIE Posted August 22, 2014 Author Share Posted August 22, 2014 That's one of the functions of the integration relay. Ahhhh. Thats the hidden relay on the back of the drivers footwell fusebox right? Very hard access. Quote Link to comment Share on other sites More sharing options...
David P Posted August 22, 2014 Share Posted August 22, 2014 That's the one. Quote Link to comment Share on other sites More sharing options...
Abz Posted August 22, 2014 Share Posted August 22, 2014 Mine stay switched on for 20 seconds after I lock my doors Quote Link to comment Share on other sites More sharing options...
Scott Posted August 22, 2014 Share Posted August 22, 2014 Mine stay switched on for 20 seconds after I lock my doors Almost long enough for a quarter mile run then Quote Link to comment Share on other sites More sharing options...
LOGIE Posted August 22, 2014 Author Share Posted August 22, 2014 Almost long enough for a quarter mile run then Oooch Quote Link to comment Share on other sites More sharing options...
Abz Posted August 22, 2014 Share Posted August 22, 2014 Almost long enough for a quarter mile run then But not quite! Quote Link to comment Share on other sites More sharing options...
Hassan Posted August 23, 2014 Share Posted August 23, 2014 In my TT it was a case of if the lights were left on and the engine was off as soon as you opened the door to get out they turned off Both my TTs done the same. Quote Link to comment Share on other sites More sharing options...
The Raven Posted August 23, 2014 Share Posted August 23, 2014 Mine is N/A TT convert and it dont do it, I tried and the lights stayed on after i locked the door.......im a sad panda Quote Link to comment Share on other sites More sharing options...
Abz Posted August 23, 2014 Share Posted August 23, 2014 Mine is N/A TT convert and it dont do it, I tried and the lights stayed on after i locked the door.......im a sad panda Think you need to have swapped that relay DavidP mentioned earlier in the thread. Quote Link to comment Share on other sites More sharing options...
LOGIE Posted August 23, 2014 Author Share Posted August 23, 2014 Think you need to have swapped that relay DavidP mentioned earlier in the thread. Yep seems that way. I changed both the looms behind the dash and the engine BAY loom. The integration relay has a small plug that goes into it on the TT dash loom. I cant remember if my NA had this. Just seems odd that toyota would have made only TTs to have an auto lights off function. Quote Link to comment Share on other sites More sharing options...
Scott Posted August 23, 2014 Share Posted August 23, 2014 Yep seems that way. I changed both the looms behind the dash and the engine BAY loom. The integration relay has a small plug that goes into it on the TT dash loom. I cant remember if my NA had this. Just seems odd that toyota would have made only TTs to have an auto lights off function. N/A owners are never in a hurry, always plenty of spare time to jump the car. Quote Link to comment Share on other sites More sharing options...
