DodgyRog Posted March 26, 2014 Share Posted March 26, 2014 Had a bit of time to kill this evening, so thought I should make a start on a couple of little bits How the Aux Pulley started and after a bit of work and a before Power Steering Res and after Need to finish the Power Steering Res and then get on with the ThrottleBody and Inlet, guessing that may take a bit longer:taped: Quote Link to comment Share on other sites More sharing options...
Mario Posted March 26, 2014 Share Posted March 26, 2014 :thumbs:Doing it all by hand? Quote Link to comment Share on other sites More sharing options...
mwilkinson Posted March 26, 2014 Share Posted March 26, 2014 That is some good work. Do you have a bench polisher setup? Quote Link to comment Share on other sites More sharing options...
DodgyRog Posted March 26, 2014 Author Share Posted March 26, 2014 :thumbs:Doing it all by hand? Not totally by hand;) That is some good work. Do you have a bench polisher setup? I use a drill, I bought a flexible extension for the drill, which is making it much easier, arm use to start aching after 15 mins holding the drill I still do the final couple of polishes by hand though, it's just easier to get a good finish by hand and spot the little bits to do Quote Link to comment Share on other sites More sharing options...
TrickTT Posted March 27, 2014 Share Posted March 27, 2014 Power steering res is mild steel and will be rusty in no time. You will need to clear coat it. Quote Link to comment Share on other sites More sharing options...
Slam Posted March 27, 2014 Share Posted March 27, 2014 What product are you using Rog Quote Link to comment Share on other sites More sharing options...
DodgyRog Posted March 27, 2014 Author Share Posted March 27, 2014 Power steering res is mild steel and will be rusty in no time. You will need to clear coat it. Thanks for that bud, I will get onto that What product are you using Rog A few, Autosol, Britemax Cut and Britemax Finish, a fine wet and dry sand paper if needed Quote Link to comment Share on other sites More sharing options...
ripped_fear Posted March 28, 2014 Share Posted March 28, 2014 Good work mate looking good Power steering res is mild steel and will be rusty in no time. You will need to clear coat it. You sure?! they arnt painted from the factory and don't rust. Plus I polished mine about 2-3 years ago and its still fine. Quote Link to comment Share on other sites More sharing options...
Westy Posted March 28, 2014 Share Posted March 28, 2014 Looking good mate! Are your fingers not aching!?lol Quote Link to comment Share on other sites More sharing options...
BOB B Posted March 31, 2014 Share Posted March 31, 2014 Good work mate looking good You sure?! they arnt painted from the factory and don't rust. Plus I polished mine about 2-3 years ago and its still fine. I agree Jake, did mine years ago, just polished, no clear coat Quote Link to comment Share on other sites More sharing options...
