Greddy Copy Inlet manifolds
alex341
What are peoples experiences with these? I'm looking to change my stock inlet, ideally I'd use a genuine greddy item but with the rest of my build getting out of hand my funds are dwindling.
I've heard of sealing problems where they bolt to the inlet tubes (this would not be an issue as i could easily weld them.) Are there any other issues? Would I simply be better sticking with the stock Toyota inlet?
There are loads on eBay at the minute, I've got a raw cast one, yes it needed a bit of port matching but it's pretty good quality. A lot better than the chromed versions I've seen. I've also been told the greddy ones have been known to have sealing issues too
650 maybe a tad more
Should be fine if not better then stock.
Just don't go chasing 900+ with it, you probably can get the power but hypertune and other equivalents would flow a lot better which equals to better powerband
