Tyre size??
Hassan
Rim width~Minimum tyre width~Ideal tyre width~~~Maximum tyre width
8,5 Inches~~~~225 mm~~~~~235 or 245 mm~~~~~~255 mm
9,0 Inches~~~~235 mm~~~~~245 or 255 mm~~~~~~265 mm
9,5 Inches~~~~245 mm~~~~~255 or 265 mm~~~~~~275 mm
10,0 Inches~~~255 mm~~~~~265 or 275 mm~~~~~~285 mm
10,5 Inches~~~265 mm~~~~~275 or 285 mm~~~~~~295 mm
11,0 Inches~~~275 mm~~~~~285 or 295 mm~~~~~~305 mm
11,5 Inches~~~285 mm~~~~~295 or 305 mm~~~~~~315 mm
12,0 Inches~~~295 mm~~~~~305 or 315 mm~~~~~~325 mm
12,5 Inches~~~305 mm~~~~~315 or 325 mm~~~~~~335 mm
Edited by listy (see edit history)
They do fit but got a slight rub. Im getting the arches rolled monday morning.
Do you guys think With my 38et, 9.5 wide and 295 tyre will i be able to use a 10mm wheels spacer?
If it rubs as it is, then even with an arch roll, I doubt it. Maybe with an aggressive arch pull like I have, but not with just a roll I don't think.
