diff type help!
tkddav3
hey ma brudddddas! well as some of you know that i blew my diff, my vin plate sais it has an a02b diff so thats what im going with.
my question is what diff types will fit? without having to change the prop or driveshafts ect? and what are the differences between the diff's?
and before you all say...yes ive used the search button!
cheers bro's n hoes
I think the below is correct....
The first letter denotes the size of the casing & crown wheel: I.e. A = small 200mm CW, B= Large 220mm CW.
The last letter denotes if it's an Open or Limited Slip Differential: A= Open, B=LSD.
The 0 never seems to change.
The number/3rd character denotes the ratio. e.g. yours is two, so your ratio is 3.769:1.
I'd look out for a B03B, big case LSD stock torsen if you want a cheap strong option, with the J-Spec TT6 ratio 3.266:1, this will improve your economy as well at a cruise, but you will lose acceleration.
However, i'm not sure if you need a different prop for that.... the flange on the big case is bigger and it sits further forward in the tunnel. the rear section of your prop might have been swapped?
However if you happen to enjoy proper traction, i'd look out for big case diff with a TRD LSD with the ratio of your choice. :)
Edited by TheTurtleshead (see edit history)
You sir, get an A+
I believe you need to swap one of the drive shafts (maybe the left one ) as the diff is wider one side.
Yep, an A02B is a small case, 3.769:1 LSD (found commonly in the TT Auto).
Drive shafts would have to change for the B03B I'd have thought?!
Also, when I changed from an A01A (4.083:1 open diff) to an A02B I had to change the diff flange as well as it was to be mated to my W58 5 speed box. :)
  • 1 month later...
