J-Spec vs US-Spec
Samurai 20V
All I know is I went head to ahead with a chap whose name I don't remember at thunder road. My uk bpu auto vs his jspec bpu auto. Almost the same mods...
We were both surprised how easily I pulled away on the 2nd tubby. 1st tubby wasn't much different
And I too highly doubt the 410 wheel bhp comment. More like fly bhp
Nic
US/UK turbos (CT12B) have smaller turbine wheels and narrower shaft/bearing diameter compared to the J-spec turbos (CT12A).
http://www.turbointernational.com/im...log-Toyota.pdf
^^Aren't the JDM spec turbo's the CT20A's and the CT12A used in the 1JZ-GTE? I'm confused now.
ct 20 compr inlet.jpgct 20 turbine out.jpgct 20 compr outlet.jpgct 20 turbine.jpg
@OP
The export version of the 2JZ-GTE achieved its higher power output with the use of newer stainless steel turbochargers (ceramic for Japanese models), revised camshafts, and larger injectors (550 cc/min for export, 440 cc/min for Japanese). Additionally, the export-exclusive CT12B turbine received more durable turbine housings and stainless steel turbine and impeller fins. In my understanding a safe boost level for the ct20's would be considered at 1,2 bar and for more reliabillity 1 bar.
