scott87 Posted October 4, 2012 Share Posted October 4, 2012 Ok so i had loads of exhaust help but just want to make totally sure before i hit buy that this is the right one for my 1995 n/a. This can be deleted after the first person says yes http://www.ebay.co.uk/itm/180775878443?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649#ht_500wt_971 Link to comment Share on other sites More sharing options...
Westy Posted October 4, 2012 Share Posted October 4, 2012 Says its for a TT non VVTi mate!? Link to comment Share on other sites More sharing options...
SPG Posted October 4, 2012 Share Posted October 4, 2012 TT and NA sup's share the same second cat dimensions, will fit fine. Link to comment Share on other sites More sharing options...
scott87 Posted October 7, 2012 Author Share Posted October 7, 2012 Thanks for the reply. I'm assuming you can fit this direct to the standard exhaust? As in keep standard parts either side of this Link to comment Share on other sites More sharing options...
Nic Posted October 7, 2012 Share Posted October 7, 2012 Thanks for the reply. I'm assuming you can fit this direct to the standard exhaust? As in keep standard parts either side of this Yes it should be a direct replacement for the 2nd cat. Link to comment Share on other sites More sharing options...
scott87 Posted October 8, 2012 Author Share Posted October 8, 2012 Bought :-D Link to comment Share on other sites More sharing options...
Benjy Posted October 8, 2012 Share Posted October 8, 2012 So when i go TT/Big single, whichever happens first, the 2nd de-cat will still fit and my HKS HiPower centre and rear section will still fit? Link to comment Share on other sites More sharing options...
scott87 Posted October 8, 2012 Author Share Posted October 8, 2012 I believe so. Link to comment Share on other sites More sharing options...
Noz Posted October 9, 2012 Share Posted October 9, 2012 TT and NA exhausts both use the same bends for the 2nd cat, and will both suit the NA or TT system. My NA even has twin heat shields for a TT setup. Thing is, most NA systems are 2.5". So if you go TT or Big Single, your limited with that pipe work. 3" min on big single. 2.5" on BPU is fine but anymore your want to be swapping it out. It' like a bottle neck effect, if you dont know what you've got measure it as if you choose to go big single and fork out lots of money the exhaust components may sneak up on you and hold you back. Link to comment Share on other sites More sharing options...
pbryant_knight Posted October 9, 2012 Share Posted October 9, 2012 Yep, thats the one i just got for my N/A mate and it works a treat Link to comment Share on other sites More sharing options...
Benjy Posted October 9, 2012 Share Posted October 9, 2012 TT and NA exhausts both use the same bends for the 2nd cat, and will both suit the NA or TT system. My NA even has twin heat shields for a TT setup. Thing is, most NA systems are 2.5". So if you go TT or Big Single, your limited with that pipe work. 3" min on big single. 2.5" on BPU is fine but anymore your want to be swapping it out. It' like a bottle neck effect, if you dont know what you've got measure it as if you choose to go big single and fork out lots of money the exhaust components may sneak up on you and hold you back. Oooh. Mine's 3.5" anywho! Win! Link to comment Share on other sites More sharing options...
Noz Posted October 10, 2012 Share Posted October 10, 2012 the system or the decat pipe? i would of thought your loosing power on a 3.5" full system on an NA Link to comment Share on other sites More sharing options...
Benjy Posted October 10, 2012 Share Posted October 10, 2012 2nd decat back. Got a stainless 6-2-1 fanimold on it. Link to comment Share on other sites More sharing options...
Noz Posted October 10, 2012 Share Posted October 10, 2012 Blimey, surprised you haven't lost any power. Bet it sounds awesome though! Ready for that TT lump Link to comment Share on other sites More sharing options...
Benjy Posted October 10, 2012 Share Posted October 10, 2012 It gained an extra 12bhp by taking both cats out and fitting that manifold. It sounds awesome, just lacking BOOOOOSHT! Lol I've got my eye on the right bits and bobs, don't you worry. Link to comment Share on other sites More sharing options...
