Newbie: warning light help
v6shep
Obviously this will have been answered elsewhere, but I'm on school run and havent got time to search, but twice it's happened now around 70 mph I get a dash warning light:
Any help appreciated, thanks, shaun
it will be your active spoiler switch, if it been removed it will be showing up that its not working switch off the active spoiler with the button on the dash and it shouldnt come on again, mine did the same when i first got my supra.
Cheers fellas, I haven't seen an active spoiler button lol.
Interior bulb no coming on (only one of these work anyhows)
And no buddy, still catted, only got an HKS backbox on, still silences half way down.
But... So far, bonnet seems likely possibility
If it is coming on at a certain speed it's usually either - as said - the active spoiler has been removed or a problem with the speed delimiter/mph convertor. A diagnostic check should tell you if there are any fault codes stored on the ECU, see how to guide here http://www.mkivsupra.net/vbb/showthread.php?35920-How-To-Check-the-diagnostics-codes&highlight=codes
If the light is coming on randomly, particularly when braking or going up/down a hill it could be the brake fluid level needs topping up - the sensor is very sensitive and can bring up a warning even if the brake fluid is slightly above the min mark.
I had this problem! And then it started flickering as I was driving then realised my boot was open slightly. After shutting it the light came back on again shortly after whilst giving it the beans but then goes off after turning the ignition off then on again?
Which means I need to.... :s
Check the speed sensor which is mounted on the upper side of the gearbox closest to the car's underside and it's connection is quite fiddley to get to.
Speed sensor - Put the car over a pit or raise it on a jack. Look on top of the gearbox for a connector with three wires (red, Yellow and IIRC Red/Blue). This is the speed sensor's connector. Check that connection for damage, secure fastening etc.
