SupraDan24 Posted April 8, 2012 Share Posted April 8, 2012 I see alot of threads asking whether certain offsets will fit stock arches, but don't see much about rolled arches. What's the maximum you gain you could expect to see from rolled arches, i think i've read 15mm somewhere before? If 15mm is the case, what would be the lowest offsets capable on the front and rear for the following: For every half inch in width, does the maxium offset decrease by 12.7mm? Front 8j: 9j: Rear 9j: 9.5j: 10j: 10.5j: 11j: Link to comment Share on other sites More sharing options...
ripped_fear Posted April 8, 2012 Share Posted April 8, 2012 Jamesy ran his SSR's as the following Front: 18x9.5 et25, Rear: 18x11 et24 Link to comment Share on other sites More sharing options...
SupraDan24 Posted April 8, 2012 Author Share Posted April 8, 2012 (edited) Hmm and his arches were just rolled were they not? Least i know the wheels i'm looking at would fit then. Edit: I've just had a look at his profile and it says they were custom flared to 20mm, i'm assuming thats referring to the work he had done after his arch roll. Edited April 8, 2012 by SupraDan24 (see edit history) Link to comment Share on other sites More sharing options...
ripped_fear Posted April 8, 2012 Share Posted April 8, 2012 Hmm and his arches were just rolled were they not? Least i know the wheels i'm looking at would fit then. They where but iirc the fronts where pulled out too. Also he ran stretched tyres. Link to comment Share on other sites More sharing options...
JamieP Posted April 8, 2012 Share Posted April 8, 2012 With sensible suspension settings and tyres that fit the wheels 9" +35 and 10" +35 fit well with rolled arches. Use the offset calculator to work out the difference for other width wheels. http://www.1010tires.com/WheelOffsetCalculator.asp Link to comment Share on other sites More sharing options...
SupraDan24 Posted April 8, 2012 Author Share Posted April 8, 2012 With sensible suspension settings and tyres that fit the wheels 9" +35 and 10" +35 fit well with rolled arches. Use the offset calculator to work out the difference for other width wheels. http://www.1010tires.com/WheelOffsetCalculator.asp I can work out the difference in mm of the offsets no problem, its knowing whether it will fit or not thats bothering me. I know 10" ET35 will fit rolled Rear arches no problem, but how much further could you go ie will say 10" ET25 fit, or 9" ET25 on the fronts. Link to comment Share on other sites More sharing options...
JamieP Posted April 8, 2012 Share Posted April 8, 2012 ET25 will fit if you want to stretch the tyres, I had a 10" et25 on the V8 supra but i could only get a 265 tyre on it. 10"ET35 with a 285/295 tyre is the perfect fit imo. Link to comment Share on other sites More sharing options...
Littler Posted April 8, 2012 Share Posted April 8, 2012 mark p is running an 11.5" wheel on the rear on his with just an arch roll, I'm trying to find out his offset but they are off for a refurb http://www.mkivsupra.net/vbb/showthread.php?266627-10-5x18-wheel-with-275-35-18-tyre-fit-under-an-unmodified-rear-arch Link to comment Share on other sites More sharing options...
SupraDan24 Posted April 8, 2012 Author Share Posted April 8, 2012 (edited) ET25 will fit if you want to stretch the tyres, I had a 10" et25 on the V8 supra but i could only get a 265 tyre on it. 10"ET35 with a 285/295 tyre is the perfect fit imo. Cheers Jamie Thats disappointing though, i'm looking at some wheels in 10" et25 but ive got some 275 Avons sat at home ready to go on mark p is running an 11.5" wheel on the rear on his with just an arch roll, I'm trying to find out his offset but they are off for a refurb http://www.mkivsupra.net/vbb/showthread.php?266627-10-5x18-wheel-with-275-35-18-tyre-fit-under-an-unmodified-rear-arch They must be ET50 or something. Could they be stretched OEM wheels maybe? Edited April 8, 2012 by SupraDan24 (see edit history) Link to comment Share on other sites More sharing options...
Nic Posted April 8, 2012 Share Posted April 8, 2012 These are 18x9 +32/18x10 +32 with the wheel arches rolled Link to comment Share on other sites More sharing options...
James Posted April 8, 2012 Share Posted April 8, 2012 Marc (AB10) runs 18x9.5 +24 up front and 18x11 +22 at the rear. Stock arches with a roll. Think the fronts may be pulled too. Link to comment Share on other sites More sharing options...
SupraDan24 Posted April 8, 2012 Author Share Posted April 8, 2012 Marc (AB10) runs 18x9.5 +24 up front and 18x11 +22 at the rear. Stock arches with a roll. Think the fronts may be pulled too. Wow, that is quite some roll on the rear. I'm convinced i can get a 18x10 +25 on the rear now then, just have to hope my wheels sell so i can make an offer the other set i'm watching. A nice set of deep dish bling wheels win finish my car off nicely Link to comment Share on other sites More sharing options...
James Posted April 8, 2012 Share Posted April 8, 2012 Marc is running 265s with them I believe. Can't remember the aspect ratio though. https://fbcdn-sphotos-a.akamaihd.net/hphotos-ak-snc6/250160_215301145168461_100000657300793_678955_1095700_n.jpg Link to comment Share on other sites More sharing options...
SupraDan24 Posted April 8, 2012 Author Share Posted April 8, 2012 God i want his wheels Link to comment Share on other sites More sharing options...
mattdavies Posted April 11, 2012 Share Posted April 11, 2012 I'm running a 18x10 ET20 with a 255 on it at the rear and with a roll it is perfect Link to comment Share on other sites More sharing options...
SupraDan24 Posted April 11, 2012 Author Share Posted April 11, 2012 I'm running a 18x10 ET20 with a 255 on it at the rear and with a roll it is perfect Ahh nice one Matt, i have got a set of 275's to go on but the wheels i am looking at are only ET25 so they should be okay Link to comment Share on other sites More sharing options...
mattdavies Posted April 11, 2012 Share Posted April 11, 2012 Yeh I would say if they were 5mm further in then could run bigger tyres Link to comment Share on other sites More sharing options...
SupraDan24 Posted April 11, 2012 Author Share Posted April 11, 2012 Yeh I would say if they were 5mm further in then could run bigger tyres I imagine so. Least now i know what i can go up too if i dont end up buying these wheels. Link to comment Share on other sites More sharing options...
