Minor accident now car is pulling to the left what can it be?
Brazil
I had a minor car accident last week and managed to give my front passenger wheel a good wack; since then I had the wheel refurbished and the car aligned though the car drives in a straight line if I let go of the steering wheel it pulls to the left.
The man that got the car aligned could not free the driver’s side wheel alignment adjusting bolt so he got did his best to get i as aligned as possible the first time I drove out it pulled really bad so I took it back to him and asked him to put it back to the way it was before which improved some.
From looking at both sides it looks like the wheel that got a wack is sitting further in the arches. Could it be because of a bent coilover or front arm?:(
Could be the arm, you should be able to see it from underneath, sounds like the tracking was properly done though. Do you have any knocking noises? If so I would of said suspension is fubar.
There's no knocking noises just pulling to the left..!
Which adjusting bolt couldn't your man get undone ? Track adjustment or one of the two eccentric camber adjusters ?
Without seeing how the wheel sits then it could be a bent hub, bent track rod or bent bottom arm.
The hub is weaker than the bottom arm so my money would be on the hub being bent.
I had a whack on the rear wheel and couldn't get the camber right. I had to change both bottom arms hub axle carrier and hub now it camber is fine. I would say it might be the same for you. It will either be bottom arm hub or hub carrier or it could be all depending how hard you hit it.
I am trying to find out which one it is by looking at the online supra manual but I can't seem to find a clear diagram.
The bolt that is seized which the car alignment man can not adjust is part number 90170-14012 as found in the link below. Which parts will I need to replace it? Should I replace both sides?
http://www.toyodiy.com/parts/p_J_2000_TOYOTA_SUPRA_JZA80-ALFVZ_4505.html
I've no idea what that is other than guessing by looking at the list and its price its probably
the lock nut on the trackrod end.
You need to see whats bent before buying parts, how big a hit on the wheel was it ?
Can you post some pics of the wheel now as to how it sits and the damage done to it
to give us an idea on the level of impact it had and what did you hit, was it the kerb ?
At the least if the camber has been knocked in then it will be the hub and or the bottom
wishbone thats bent. Along with the eccentric adjusters possibly but their pretty easy
to check once their removed.
When your guy looked at it what was the camber at before he started trying to adjust
it ? also what was the toe ?
I don't have the camber and toe data as I never asked for it and the man did not explain it to me I was also at the end of a very long day.
  • 2 weeks later...
Without knowing then i'd just be guessing, if the camber is out and the toe then i'd be replacing the bottom
wishbone and the hub and then take it from there.
Up Date:
I took my car to a race car specialist garage and they confirmed to me what Dunk has told me, which is unless they have the alignment data it's very difficult to identify where it damaged is. When I first took my car to the car alignment garage they could not get the car aligned because they said they weren’t able to adjust the steering rod bolt.
My damaged wheel is back and all wheels have been fitted with new valves which I purchase from the UK therefore I shouldn't have any more unexpected flats and more damaged wheels. Next the car will be going to get alignment work, this time in a different place one that has experience working with sports cars and I’ve told them to do what it takes to get the car aligned even if it means replacing the steering rod & bolt.
My question is what camber and toe setting would best suit my car? My current wheel and tyre specification is (rear) Toyo R888 295, 30, 19 and in the (front) Bridgestone Potenza 245,35,19 'when its worn out I will be changing it to Toyo R888 and a bit wider 255.
Whats your email address and i'll send you my settings, i think you need to be very carefull though
as its more than likely the hub is bent.
Would a bent hub give the impression that the wheel is sitting deeper in the arches? The garage shouldn't charge me to find out whats wrong so thats a big weight of my shoulders.
The main reason to have the car aligned is so the mechanic can use the date to try to identify where its bent. It will need to be aligned again after all suspension work, I want to replace all the bushings and coilover but the mechanic is telling me that first we need to fix/know for sure the current problem.
My email: [email protected] (Thanks)
Edited by Brazil (see edit history)
I'd be supprised if you've bent the coilover, the first things to look at are the track rod, the bottom arm and the hub.
I'll email you my settings which are on 255 x 19 fronts and 295 x 19 rears with
30mm lowered front and 25mm lowered rear
It also depends on how the car impacted the kerb. Di you slide side ways against it or did the car more roll hard into and up it?
If it was a sideways impact I would think more along the lines of the bottom arm, however, this would show as the wheel seeming to be leaning out of the arch as opposed to seeming to lie deeper into it. Hitting and rolling up a kerb hard would manifest in a bent hub (or more commonly this would be the case anyway)....this would also make the wheel seem as if it was sitting 'further into' your wheel arch and possibly as if it is more cambered than it was before.
Just my thoughts, having done similar myself a few times in different cars and also seeing friends cars with similar damage.
Thank's buddy, got the email...!
