spikedjack Posted January 16, 2012 Share Posted January 16, 2012 Looking to purchase a coilover setup shortly, and these two seem to have jumped out to me. A good friend is running the HSD's on his RX7 FD3S and honestly i cant fault them, however, after reading many reviews and oppinions both on here and elsewhere, it seems that people either suggest HSD's or Meister R Zeta R's, and when looking at them seem to be very very similar with the only differences being: 1) the meister R's being £75 cheaper 2) the meister R's using a 14kg/8kg spring rate and the HSD's using an 18kg/10kg spring rate What would you guys prefer and why? Many thanks. Quote Link to comment Share on other sites More sharing options...
fastcar Posted January 16, 2012 Share Posted January 16, 2012 I'm going for the miester r just because of the softer spring rate. I think it would be a better setup for the road if I'm honest that's the only reason why I'm going for them. I think as in terms of build quality and how the damper works they will both be the same Quote Link to comment Share on other sites More sharing options...
Scott Posted January 16, 2012 Share Posted January 16, 2012 Looking to purchase a coilover setup shortly, and these two seem to have jumped out to me. A good friend is running the HSD's on his RX7 FD3S and honestly i cant fault them, however, after reading many reviews and oppinions both on here and elsewhere, it seems that people either suggest HSD's or Meister R Zeta R's, and when looking at them seem to be very very similar with the only differences being: 1) the meister R's being £75 cheaper 2) the meister R's using a 14kg/8kg spring rate and the HSD's using an 18kg/10kg spring rate What would you guys prefer and why? Many thanks. I wanted the Zetas to replace my HSDs but only because of the colour scheme, I just went with painting my HSDs instead The only real difference as far as I can tell is the spring rates. It will all come down to what you use the car for at the end of the day. If you want it to be stiffer and have sportier handling then the HSDs are the way to go, if you want comfort and a pleasant-ish ride then the Zeta Rs are the way to go. The build quality of the HSDs is really good, they feel really solid when puttingg them on the car. I recently stripped mine down for painting and although the thread for adjusting was manky (as all are regardless of brand) they still came apart no bother at all. Quote Link to comment Share on other sites More sharing options...
spikedjack Posted January 16, 2012 Author Share Posted January 16, 2012 The HSD's on the RX7 seem to ride lovely, however looking at the spring rates for the supra, although they are a much fatter car, i seem to think they may be bone shakingly stiff. Looking at other coilovers on the market (cusco Hks etc) they all seem to run similar rates to that of the meister's.... Quote Link to comment Share on other sites More sharing options...
Scott Posted January 16, 2012 Share Posted January 16, 2012 The HSD's on the RX7 seem to ride lovely, however looking at the spring rates for the supra, although they are a much fatter car, i seem to think they may be bone shakingly stiff. Looking at other coilovers on the market (cusco Hks etc) they all seem to run similar rates to that of the meister's.... The HSDs are anything but bone shaking. I had TRD Bilsteins with TRD springs and THOSE were teeth rattlers. I also got Megan Racing Coilovers which were similar to the HSDs but not quite as soft and the build quality wasn't as good. They are perfect for me as I'm looking for a balance between handling and comfort, with more of an air towards handling. The Meisters will be the opposite. Quote Link to comment Share on other sites More sharing options...
spikedjack Posted January 16, 2012 Author Share Posted January 16, 2012 just the spring rates more than anything thats concerning... Given they are in old money numbers, if my maths is correct the ratings are: Stock: 430 lb/inch or 6kg/mm front 219 lb/inch or 4kg/mm rear The HSD's seem to be tripling these rates?! surely 3 times as stiff cant be correct? Quote Link to comment Share on other sites More sharing options...
Scott Posted January 16, 2012 Share Posted January 16, 2012 just the spring rates more than anything thats concerning... Given they are in old money numbers, if my maths is correct the ratings are: Stock: 430 lb/inch or 6kg/mm front 219 lb/inch or 4kg/mm rear The HSD's seem to be tripling these rates?! surely 3 times as stiff cant be correct? Adjustable coilovers will always be like that though as they don't have much travel. The softer the spring the more chance of it bottoming out when pushing it. The higher spring rate is required when driving hard on adjustable coilovers. Edit: I'm pretty sure the stock front rate is 8kg/mm rather than 6. Quote Link to comment Share on other sites More sharing options...
spikedjack Posted January 16, 2012 Author Share Posted January 16, 2012 Seems like the HSD's seem to be slightly more performance orientated then with the Meisters more 'Show' as such? Quote Link to comment Share on other sites More sharing options...
Scott Posted January 16, 2012 Share Posted January 16, 2012 Seems like the HSD's seem to be slightly more performance orientated then with the Meisters more 'Show' as such? Yes but I wouldn't really say "show" as such. They are both going to be more performance orientated than stock, it's just that one set has went more towards performance and one set has stayed closer to comfort. I had a little google for the stock spring rates and I'm almost positive the ones you have quoted are UK spec rather than JDM which are a fair bit stiffer to begin with. Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted January 16, 2012 Share Posted January 16, 2012 zeta r all day for me. there is more scope on the damper adjustment and i just didnt like the way hsd feel. plus the after sales care from miester r is very good. allways happy to advise over the phone and offer different rates to suit what you want Quote Link to comment Share on other sites More sharing options...
Guigsy Posted January 16, 2012 Share Posted January 16, 2012 I have hsd on my uk and liked them. And I have hks on my single. And the hks are much harder... If that helps. But for road use... I'd rather have my original uks back Quote Link to comment Share on other sites More sharing options...
imi Posted January 16, 2012 Share Posted January 16, 2012 have HSDs on mine - very happy with them - cant comment on their after sales and have needed to use them. lookout for groupbuys as you can pick them up for a great price. Quote Link to comment Share on other sites More sharing options...
Littler Posted January 16, 2012 Share Posted January 16, 2012 I have HSD's fitted to mine, very happy with them if I'm honest. Could I ask for those who have them what setting you have the stiffness adjusted too out of the "16 clicks"?? Just curious. Quote Link to comment Share on other sites More sharing options...
Scott Posted January 16, 2012 Share Posted January 16, 2012 I have HSD's fitted to mine, very happy with them if I'm honest. Could I ask for those who have them what setting you have the stiffness adjusted too out of the "16 clicks"?? Just curious. I think I'm on 10 at the front and 8 at the rear. Quote Link to comment Share on other sites More sharing options...
Littler Posted January 16, 2012 Share Posted January 16, 2012 I think I'm on 10 at the front and 8 at the rear. Are you finding that to be a good firm setup? Quote Link to comment Share on other sites More sharing options...
Scott Posted January 16, 2012 Share Posted January 16, 2012 Are you finding that to be a good firm setup? Handles great for me, it's never going to be like driving on a cloud but it certainy keeps in check over bumps/mini potholes etc. Quote Link to comment Share on other sites More sharing options...
Littler Posted January 16, 2012 Share Posted January 16, 2012 Handles great for me, it's never going to be like driving on a cloud but it certainy keeps in check over bumps/mini potholes etc. I may have to try it as I've been trying to come up with a good setup. Quote Link to comment Share on other sites More sharing options...
Scott Posted January 16, 2012 Share Posted January 16, 2012 I may have to try it as I've been trying to come up with a good setup. Thinking about it now I think it's actually 10 and 12. I was thinking I had the setting lower on the rear but I think I actually have it higher (so that it doesn't try to hop). It's definitely in the mid-upper range anyway. Anywhere around that sort of setting should be good for some fun fast road without wanting to spin you into a ditch when you roll over a pebble. Quote Link to comment Share on other sites More sharing options...
Littler Posted January 16, 2012 Share Posted January 16, 2012 Thinking about it now I think it's actually 10 and 12. I was thinking I had the setting lower on the rear but I think I actually have it higher (so that it doesn't try to hop). It's definitely in the mid-upper range anyway. Anywhere around that sort of setting should be good for some fun fast road without wanting to spin you into a ditch when you roll over a pebble. I'll give it a go once this weather has sorted itself out! Cheers Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted January 16, 2012 Share Posted January 16, 2012 Ring both suppliers, say you have a leaking or knocking damper, and ask for an estimate and time frame to rebuild it... Not mentioning any names, and it was neither of those two brands, but one new damper I was playing with the other day exhibited signs of low gas charge. My mate who is into gas testing was hanging about and we sniffed the gas to see it was nitrogen, as it should be. The **gg*rs had filled them with plain compressed air. All 4 were the same, straight out of their packing Quote Link to comment Share on other sites More sharing options...
Scott Posted January 17, 2012 Share Posted January 17, 2012 The **gg*rs Not quite PC that one is it Chris Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted January 17, 2012 Share Posted January 17, 2012 b***er, never thought of that, trust you! You'll be calling me Paul next. Quote Link to comment Share on other sites More sharing options...
fastcar Posted January 17, 2012 Share Posted January 17, 2012 Ring both suppliers, say you have a leaking or knocking damper, and ask for an estimate and time frame to rebuild it... Not mentioning any names, and it was neither of those two brands, but one new damper I was playing with the other day exhibited signs of low gas charge. My mate who is into gas testing was hanging about and we sniffed the gas to see it was nitrogen, as it should be. The **gg*rs had filled them with plain compressed air. All 4 were the same, straight out of their packing That's very intresting and disturbing. Just out of intrest was it one of the well knowen budget brands? Quote Link to comment Share on other sites More sharing options...
spikedjack Posted January 17, 2012 Author Share Posted January 17, 2012 Ring both suppliers, say you have a leaking or knocking damper, and ask for an estimate and time frame to rebuild it... Not mentioning any names, and it was neither of those two brands, but one new damper I was playing with the other day exhibited signs of low gas charge. My mate who is into gas testing was hanging about and we sniffed the gas to see it was nitrogen, as it should be. The **gg*rs had filled them with plain compressed air. All 4 were the same, straight out of their packing Not a bad idea there chris, thankyou for the imput! Quote Link to comment Share on other sites More sharing options...
SamuraiFlash Posted February 13, 2012 Share Posted February 13, 2012 Would a stiffer suspension setup hinder the grip the tyres have in the wet? Quote Link to comment Share on other sites More sharing options...
