just fitted both de cats
Guest cossiedave
Guest cossiedave
recieved my de cats today from chris wilson who was great to deal with and gave great service, i fitted them tonight and the car sounds great with the connected to my 4 inch hks dragar so now thinking of mapping, what options do i have regarding mapping and what is max power on standerd injectors
Guest cossiedave
its a tt import and yes i did put the r/r in , my skyline runs the link g4 ecu so would some thing like that do the job as mine is standerd i think at the moment
Just get a boost controller and crank the boost up to 1.2bar. You won't get a lot more out of it with a remap, not worth it for the money involved IMO.
If you can get a hold of a Mines ECU, or other aftermarket variety, then they are good little upgrades for power.
Max you will see out of the stock tubbys will be 380-430hp. As long as you are inside that band you are going to be very happy and you won't really have much scope for more power without spending a LOT of cash.
If your thinking of changing your ecu you need to ask yourself if whether you are planing to stay with the standard tubbys or thinking of going single. As it will affect what kind of ECU would be best for you. IE if your keeping standard tubbys then piggy back ECU will do if your going single then you will need a standalone to get the best out of your setup.
Just keep the stock ECu you'll only see around 30bhp tops with a standalone ECU so its not really worth it As Scott says, get a boost controller, whack it up to 1.6 (assuming you have a FCD) and a better fuel pump, a decent FMIC or new SMIC wouldnt go amiss either. Then away you gooooooo
The turbo's will go faster than he will if he cranks it up to 1.6 ;)
Guest cossiedave
i all ready have a hks front mount so all i need now is a fcd and boost controller then job done, i wont be going down the single turbo route as i have just done that on my r34 and dont fancy all the messing and pipe making lol
i meant 1.2 Scott. You'll be able to sleep tonight now you've had your daily dose of correcting someone ;)
Daily you say?
Lol gotta get your priorities right, True Blood rocks, Sookey is so fit :p
What a cracking name for a female vampire :D
At standard BPU levels the car should make around 380-400hp (flywheel) at 1.2bar, with the addition of cams and ECU/remap 430hp (flywheel) is around the maximum you can expect.
As said you will need cool grade spark plugs otherwise you'll get misfire at the higher boost levels, see HERE
Is it a manual or an auto? If manual I have an interesting Veilside modified plug and play ecu for you at a good price, or I have a Motec M600, adapter loom and ancillaries to make it a high end mappable system, virtually plug and play. If it's an auto your options are more limited. I also have some cheap FCD's coming in next week.
