Difference between 154 and w58 gearboxes (just curious).
hodge
Nope not both n/a mate. The W58 was but the R154 is for turbo cars, the Mk3 Supra turbo, JZZ Soarer tt, Chaser etc. The R154 has a steel section towards the rear, the W58 doesnt, the 154 is stronger, Id assume longer geared as well. Heres a pic, 154 on the left :)
One of the drift cars over here has r154 box in it 3 years now, running around 600hp, never had an issue with it, he actually had a spare one incase anything went wrong but sold it, I'm putting an r154 box in my car, sleeve fitment instead of bolt fitment to the drive shaft iirc
As other have mentioned, the R154 is a MUCH stronger box. There are some significant differences in the gearing, the r154 being a long geared box so be careful you know how the ratio's will play out before fitting. I can provide data on that if you need more information about the ratio's.
Usually. Unless you drive like an old lady!
You should pop up and see the progress on mine, might change your tune on my build :p
I must like slow cars :)
I wasn't implying your car is slow but with the lack of turbo, going off your build thread, and the length of the gears its will take ages to get up to speed. I also hope your internals are strong enough to turn 10k if that is what your planning.
I've stopped updating the thread with the important stuff, people just copy ideas. It comes under the "new engine" though. And no, its not a v8. :)
The twin IC's aren't, but the engine and what's bolted to it are. Not spilling any beans, but hope to turn up at Suprapod 2012 with it.
IMO, the whole point of a project thread is to share ideas with other members. I consider it an honor that people use my ideas, so to say I'm not putting details in a project thread cos people steal ideas is ridiculous. If that's the case and you don't want anyone to know what's going on, dont update the thread and have it removed. Simples.
