How many diffs available for the MKIV, only two?
Wez
Hey All,
Is there only two casings available for the MKIV?
B03B = large casing
A03B = Small casing
If these are the only two casings ever seen on a MKIV what is required to swap from one to the other, is it just drive shafts or is a prop required as well?
Are the small casings from NA auto/manuals the same as small casings from a TT auto/manual?
How easy is it to swap over the driveshafts and diff?
Thanks
:thumbs:
Facelift TT manuals do yes, pre facelift TT6 use the larger case.
As far as i know all the smaller diffs on both TT and NA are the same casing i suspect you would need to change the prop shaft flange to adapt the different types of props there are.
only 2 size casings...
early tt 6 speeds had a larger casing...later ones (facelift seemed to have smaller casings)
auto jap imports all had smaller casings
all nas had smaller casings
all uk/euro had larger casing
if intercahaging...props and shafts are needed...depending which way you went too...also noticed some nas have thinner driveshafts compared to tt
all props for all models are different...i have the codes somewhere...off the top of my head codes below...
codes can be found on a small white lable on the prop just before the donut at the back...
na auto PA48
na man 5 spd PA39
na 6 spd PA01
tt 6 early PA91
tt 6 late (same as na 6)
tt auto jap (same as vvti tiptronic) PA93
uk auto
uk man (same as early jap tt6)
na auto PA48
na man 5 spd PA39
na 6 spd PA01
tt 6 early PA91
uk auto
Great info, thanks Keron :thumbs:
I take it some of these are interchangeable and some are not.
I have a large diff casing in my 1996 RZ, I would like to fit a small casing from an auto NA, I would need driveshafts with ABS rings and possibly a prop, can you confirm?
ok all props are different lenghts etc but you can mix and match sometimes depending on what you want to interchange...
for yours...you would need one driveshaft (one is shorter on the larger casing) and also the prop ideally you would need a 6 spd late spec prop PA01 (direct fit) however you would need to change the diff end flange over to a tt version too as the prop wont mate with the na diff...
Which side driveshaft is shorter?
Would it be possible to change the diff flange to something that would work with my current prop?
My cars an N/A auto at the moment but Ive got a V161 gearbox and a torsen LSD diff from a N/A that I want to put in instead! But as above I'm having trouble with the prop that came with the V161 box fitting to the diff :(
Do you know which parts of a prop I need to make these fit together?
  • 2 weeks later...
na auto PA48
na man 5 spd PA39
na 6 spd PA01
tt 6 early PA91
uk auto
The 6spd conversion parts that I got and supposedly came off the same car!!! Don't match with the codes above :blink:
On the prop I've got it has PA93 on it! So that's a TT Auto prop!! And it should be a manual 6spd prop! Can anybody shed any light on this!?
  • 2 weeks later...
Rear sections of the TT auto and six speed prop are the same, front sections are very different. Having never seen a six speed prop, before my build, I got ripped off twice on here buying so called manual set-ups which turned out to be auto's:(
