Wez Posted April 18, 2011 Share Posted April 18, 2011 Hey All, Is there only two casings available for the MKIV? B03B = large casing A03B = Small casing If these are the only two casings ever seen on a MKIV what is required to swap from one to the other, is it just drive shafts or is a prop required as well? Are the small casings from NA auto/manuals the same as small casings from a TT auto/manual? How easy is it to swap over the driveshafts and diff? Thanks Link to comment Share on other sites More sharing options...
j_jza80 Posted April 18, 2011 Share Posted April 18, 2011 Iirc facelift TTs use the small casing too. Link to comment Share on other sites More sharing options...
Kirk Posted April 18, 2011 Share Posted April 18, 2011 Facelift TT manuals do yes, pre facelift TT6 use the larger case. As far as i know all the smaller diffs on both TT and NA are the same casing i suspect you would need to change the prop shaft flange to adapt the different types of props there are. Link to comment Share on other sites More sharing options...
keron Posted April 18, 2011 Share Posted April 18, 2011 only 2 size casings... early tt 6 speeds had a larger casing...later ones (facelift seemed to have smaller casings) auto jap imports all had smaller casings all nas had smaller casings all uk/euro had larger casing if intercahaging...props and shafts are needed...depending which way you went too...also noticed some nas have thinner driveshafts compared to tt Link to comment Share on other sites More sharing options...
Wez Posted April 18, 2011 Author Share Posted April 18, 2011 OK driveshafts is a given, whats the different props available? Link to comment Share on other sites More sharing options...
Kirk Posted April 18, 2011 Share Posted April 18, 2011 Na and TT props are of different thickness so i suspect the flange on the diff casing will be different. Also auto props are shorter than manuals i think Link to comment Share on other sites More sharing options...
ray007 Posted April 18, 2011 Share Posted April 18, 2011 Sorry to highjack You may have seen my other thread, I known someone selling a 10bolt LSD and 12 bolt LSD without casings Not sure if I can use one of them say in my current non LSD smaller casing diff? Link to comment Share on other sites More sharing options...
keron Posted April 18, 2011 Share Posted April 18, 2011 all props for all models are different...i have the codes somewhere...off the top of my head codes below... codes can be found on a small white lable on the prop just before the donut at the back... na auto PA48 na man 5 spd PA39 na 6 spd PA01 tt 6 early PA91 tt 6 late (same as na 6) tt auto jap (same as vvti tiptronic) PA93 uk auto uk man (same as early jap tt6) Link to comment Share on other sites More sharing options...
Wez Posted April 18, 2011 Author Share Posted April 18, 2011 all props for all models are different...i have the codes somewhere...off the top of my head codes below... codes can be found on a small white lable on the prop just before the donut at the back... na auto PA48 na man 5 spd PA39 na 6 spd PA01 tt 6 early PA91 tt 6 late (same as na 6) tt auto jap (same as vvti tiptronic) PA93 uk auto uk man (same as early jap tt6) Great info, thanks Keron I take it some of these are interchangeable and some are not. I have a large diff casing in my 1996 RZ, I would like to fit a small casing from an auto NA, I would need driveshafts with ABS rings and possibly a prop, can you confirm? Link to comment Share on other sites More sharing options...
keron Posted April 18, 2011 Share Posted April 18, 2011 Great info, thanks Keron I take it some of these are interchangeable and some are not. I have a large diff casing in my 1996 RZ, I would like to fit a small casing from an auto NA, I would need driveshafts with ABS rings and possibly a prop, can you confirm? ok all props are different lenghts etc but you can mix and match sometimes depending on what you want to interchange... for yours...you would need one driveshaft (one is shorter on the larger casing) and also the prop ideally you would need a 6 spd late spec prop PA01 (direct fit) however you would need to change the diff end flange over to a tt version too as the prop wont mate with the na diff... Link to comment Share on other sites More sharing options...
Wez Posted April 18, 2011 Author Share Posted April 18, 2011 ok all props are different lenghts etc but you can mix and match sometimes depending on what you want to interchange... for yours...you would need one driveshaft (one is shorter on the larger casing) and also the prop ideally you would need a 6 spd late spec prop PA01 (direct fit) however you would need to change the diff end flange over to a tt version too as the prop wont mate with the na diff... Which side driveshaft is shorter? Would it be possible to change the diff flange to something that would work with my current prop? Link to comment Share on other sites More sharing options...
Chris Wilson Posted April 18, 2011 Share Posted April 18, 2011 If you take the prop flange off you SHOULD fit a new crush tube and re set the preload on the pinion bearings. I think it's the RH drive shaft that differs in length. I may have what you need, drive shaft wise, but would need an overall length to confirm. Link to comment Share on other sites More sharing options...
Andrew K Posted April 19, 2011 Share Posted April 19, 2011 ok all props are different lenghts etc but you can mix and match sometimes depending on what you want to interchange... for yours...you would need one driveshaft (one is shorter on the larger casing) and also the prop ideally you would need a 6 spd late spec prop PA01 (direct fit) however you would need to change the diff end flange over to a tt version too as the prop wont mate with the na diff... My cars an N/A auto at the moment but Ive got a V161 gearbox and a torsen LSD diff from a N/A that I want to put in instead! But as above I'm having trouble with the prop that came with the V161 box fitting to the diff Do you know which parts of a prop I need to make these fit together? Link to comment Share on other sites More sharing options...
Wez Posted April 21, 2011 Author Share Posted April 21, 2011 This is the diff I purchased from David2009 N/A 4.083 open diff and casing, suits N/A auto and N/A 5MT http://www.mkivsupra.net/vbb/showthread.php?206979-N-A-diff-n-s-drive-shaft-and-hub Link to comment Share on other sites More sharing options...
Nodalmighty Posted April 21, 2011 Share Posted April 21, 2011 NA Auto being replaced with TT auto to take advantage of Line pressure and Accumulator solenoids. Any gothcha's I should be aware of? I will have Soarer V8, TT and NA auto box and prop to mix and match bits from. Which differentials have Slippers in them? Link to comment Share on other sites More sharing options...
Andrew K Posted April 30, 2011 Share Posted April 30, 2011 all props for all models are different...i have the codes somewhere...off the top of my head codes below... codes can be found on a small white lable on the prop just before the donut at the back... na auto PA48 na man 5 spd PA39 na 6 spd PA01 tt 6 early PA91 tt 6 late (same as na 6) tt auto jap (same as vvti tiptronic) PA93 uk auto uk man (same as early jap tt6) The 6spd conversion parts that I got and supposedly came off the same car!!! Don't match with the codes above On the prop I've got it has PA93 on it! So that's a TT Auto prop!! And it should be a manual 6spd prop! Can anybody shed any light on this!? Link to comment Share on other sites More sharing options...
Terminator Posted May 8, 2011 Share Posted May 8, 2011 Rear sections of the TT auto and six speed prop are the same, front sections are very different. Having never seen a six speed prop, before my build, I got ripped off twice on here buying so called manual set-ups which turned out to be auto's:( Link to comment Share on other sites More sharing options...
