w41k3r Posted July 14, 2010 Share Posted July 14, 2010 Me and my bro have been trying to remove my crank pulley by wedging a breaker bar on the floor and cranking the engine it just stops as soon as it cranks also tried leaving the bar a little off the floor to use a bang motion but still didnt work Any ideas we also used jumper leads from my bros car to rule out crap battery lol but battery seems fine we had the breaker bar facing passanger side but nothing any other tips or am i going to have to buy the crank pulley removal tool and what crank removal tool do i buy ? is there a cheap place to buy one or does anyone have one i could lend or rent local thanks Link to comment Share on other sites More sharing options...
David Reid Posted July 14, 2010 Share Posted July 14, 2010 It sounds like you are struggling removing the pulley bolt? If you are a removal tool wont help you as you need the bolt out to remove it. My last GTR I really struggled with the crank pulley bolt in the end I borrowed a 3/4 inch inpact gun + heated it up to remove it. But you need to be careful not to apply so much heat to melt the front oil seal. Have you tried a long bar i.e scaffold tube on the end of your breaker bar, then put the car in gear have a helper hit the brakes and pull on the breaker bar? Link to comment Share on other sites More sharing options...
RobD Posted July 14, 2010 Share Posted July 14, 2010 You'll need to get the bolt out before you can use the crank pully tool! You could try and lock the flywheel up and getting a VERY big breaker bar and a gorilla to pull on it! Also try and get a big chisel and hammer and try to loosen the bolt that way, you'll need a new pulley bolt after though! Link to comment Share on other sites More sharing options...
RobD Posted July 14, 2010 Share Posted July 14, 2010 Beat me to it! Link to comment Share on other sites More sharing options...
w41k3r Posted July 14, 2010 Author Share Posted July 14, 2010 ok i need the BOLT out first thats whats not moving then the removal tool sorry for not being clear enough the bolt wont budge Link to comment Share on other sites More sharing options...
Ian Ian Posted July 14, 2010 Share Posted July 14, 2010 I know it might sound stupid of me but your are trying to undo the bolt in the right direction ? i know some bolts undo clockwise ? ( im unsure on the pully bolt direction ) just a thought thats all Cheers -Ian- Link to comment Share on other sites More sharing options...
w41k3r Posted July 14, 2010 Author Share Posted July 14, 2010 think engine cranks clockwise, bar pointing down nearside wheel direction Link to comment Share on other sites More sharing options...
dr_jekyll Posted July 14, 2010 Share Posted July 14, 2010 i just had the exact same thing , i ended up geting a crank locking tool made and bolting it to the crank pully using the 2 m8 holes that a pree drilled and tapped. i then had to remove the bonnet get a big breaker bar and a scaffolding pole and off she popped. Link to comment Share on other sites More sharing options...
Shane Posted July 14, 2010 Share Posted July 14, 2010 Mate you need to make a tool. Once you have you will wish you did it from the begining. I used 2 peices of angle iron (from an old bed frame) in a Y form simply bolted at the join, though welded would be best. The longer part of the Y rests against the driver side chassis section in the engine bay. The V part of the Y sits across the pulley and requires two holes drilling for the M8 bolts to pass through into the threaded holes of the pulley which are either side of your favourite bolt. Big breaker and probably a pole to get the leverage and it will come out without the need of power tools, heat etc. I foolishly battled for a couple of days with mine until I spent half hour making a tool and then 5 minutes cracking the bolt. Honest, when they are as tight as that, IMO you need a tool, especially if it's an auto. Link to comment Share on other sites More sharing options...
w41k3r Posted July 14, 2010 Author Share Posted July 14, 2010 where can i get a cheap tool from also mines a manual Link to comment Share on other sites More sharing options...
Shane Posted July 14, 2010 Share Posted July 14, 2010 where can i get a cheap tool from also mines a manual Don't think there is a cheap one available off the shelf. Will post a picture of the rough one I made when get a mo In a Parisian bar just now. It's Bastile day! Link to comment Share on other sites More sharing options...
markssupra Posted July 14, 2010 Share Posted July 14, 2010 Try sending captainb a pm, I made one for him over 3 months ago. He may let you borrow it. You are trying to undo the crank pulley bolt anti-clockwise I assume Link to comment Share on other sites More sharing options...
Dave Posted July 14, 2010 Share Posted July 14, 2010 im sure the bolt comes off counter clockwise i did mine but used a kit from someone on here and a 6ft piece of scaffold pole came off easy they are tourqed to 320 ft lbs . Link to comment Share on other sites More sharing options...
markssupra Posted July 14, 2010 Share Posted July 14, 2010 im sure the bolt comes off counter clockwise i did mine but used a kit from someone on here and a 6ft piece of scaffold pole came off easy they are tourqed to 320 ft lbs . I am that 'someone on here' Link to comment Share on other sites More sharing options...
Shane Posted July 15, 2010 Share Posted July 15, 2010 (edited) http://i137.photobucket.com/albums/q220/shaneg7ewl/Broken%20it/IMG00254-20100530-0909.jpg OK here is the one I made, it's rough and basic and took less than half hour to make. But it works! Edited July 15, 2010 by Shane (see edit history) Link to comment Share on other sites More sharing options...
Rob Posted July 15, 2010 Share Posted July 15, 2010 I have a full set including tool to pull off the pulley, I would want a deposit by paypal prior to posting, and for you to cover posting costs which is roughly £20 each way. Link to comment Share on other sites More sharing options...
Rob Posted July 15, 2010 Share Posted July 15, 2010 im sure the bolt comes off counter clockwise i did mine but used a kit from someone on here and a 6ft piece of scaffold pole came off easy they are tourqed to 320 ft lbs . 320 Nm isn't it? Aka bastid tight. Link to comment Share on other sites More sharing options...
w41k3r Posted July 15, 2010 Author Share Posted July 15, 2010 Very kind rob but I'd be scared of using that its like bling lol I'd be scared I'd break it Link to comment Share on other sites More sharing options...
Dave Posted July 15, 2010 Share Posted July 15, 2010 I am that 'someone on here' aahhaa sorry mark couldnt remember your name .:)good tool easy to use. Link to comment Share on other sites More sharing options...
w41k3r Posted July 22, 2010 Author Share Posted July 22, 2010 Well my pulley lock up tool came today bought a sealey one for £30 first pull on the extension bar and the lock up tool broke!!!!!! so weve accepted defeat and its gone of on tow to my bros mates garage where hopefully it will be sorted absolute nightmare Link to comment Share on other sites More sharing options...
nevins Posted July 22, 2010 Share Posted July 22, 2010 I have a full set including tool to pull off the pulley, I would want a deposit by paypal prior to posting, and for you to cover posting costs which is roughly £20 each way. http://img.photobucket.com/albums/v713/aberdeenstu/DSCN7235.jpg http://img.photobucket.com/albums/v713/aberdeenstu/DSCN7237.jpg Thats very pretty ,May I ask where you acquired that. Link to comment Share on other sites More sharing options...
Ian Ian Posted July 22, 2010 Share Posted July 22, 2010 Well my pulley lock up tool came today bought a sealey one for £30 first pull on the extension bar and the lock up tool broke!!!!!! so weve accepted defeat and its gone of on tow to my bros mates garage where hopefully it will be sorted absolute nightmare Jeez that sounds a nightmare hope the garage sorts it out mate Cheers -Ian- Link to comment Share on other sites More sharing options...
Shane Posted July 22, 2010 Share Posted July 22, 2010 Well my pulley lock up tool came today bought a sealey one for £30 first pull on the extension bar and the lock up tool broke!!!!!! so weve accepted defeat and its gone of on tow to my bros mates garage where hopefully it will be sorted absolute nightmare What type of tool did you buy from Sealy, do you have a part number? I am very curious as I didnt realise there was one commercially available other than the Toyota one. Link to comment Share on other sites More sharing options...
Matt H Posted July 22, 2010 Share Posted July 22, 2010 why is this so hard to remove? Age? Link to comment Share on other sites More sharing options...
w41k3r Posted July 22, 2010 Author Share Posted July 22, 2010 it was a universal pulley lock up tool it was a long shot but was as described on here like a y shape so went with it but what a load of cr*p and matt h im not sure it must just be age weve tried allsorts the garage will try gunning it of and if not it will be heated up as a last resort Link to comment Share on other sites More sharing options...
