big handling and wheel alignment problems
dr_jekyll
hi all,
i recently smashed a 94 na-t over a rounderbout traveling at considerable speed within the law ofcorse.
amazingly even though the force managed to flatten all 4 wheels
the suspension arms and wishbones dont seem to be damaged in any way , but now the car dose not sit level at the front, the rear wheel camber is verry odd ( drivers leans alot more ) the car pulls right and feels horible through corners.
i have checked the bushes for play the wishbones measure up to spec and the chassis mounts are perfect , can anybody give me some advise on things to go through to try and get the supesiondand camber back to standard,
its on standard suspension all around , thanks
Subframe damaged? hub issue? Could be a lot of things.
I had a problem with one of the rear wheels (it was visibly toed in and had huge camber), all the components appeared to measure up and nothing was visibly wrong with them. Later found the hub was very slightly bent, again not visibly so, but after swapping with another unit the wheel was straight again. When comparing the two units and measuring there was no difference, all I can guess is that one of more of the mount points were slightly twisted.
oh bugger, well iv just found the gude to adjusting the camber so ill try that on the back and have the front tracked, and give that a try , if not looks like the credit card is comeing out again for parts :(
Ive recently changed all my suspension arms etc and wish you lots of luck finding the bent parts.
There is quite a lot of adjustment camber wise so if somethings bent you might be able to dial it out but whatevers bent will still be bent and potentially weakened by the impact.
I'd want to take a much closer look myself rather than re track it etc
ok. the rear is off and i think weve found the problem, the drivers rear top wishbone is slighly bent , unnoticeable to the eye but after mesuring in is definatle a few mm out, so can anybody tell me were i can find a replacement because there hard to come by, thanks,
also is the tt rear wishbnone the same as the n/a . thanks
Edited by dr_jekyll (see edit history)
Hi mate !
Mines doing exactly the same, changed three arms on the back, costing me over £350 and sill i've got the problem !
popped up to "extreme performance" on the weekend to see keron, who had a front end damaged insurance write off, and bought the whole back end subframe/rear axle/hubs and all the arms for a fantastic price ! gonna swap the whole lot over and hope it cures my problem !
give keron a ring (see extreme performance on traders sect.)
those upper wishbone arms are £300 odd + vat each from toyota [sHOCK][/sHOCK]
