dr_jekyll Posted January 26, 2009 Share Posted January 26, 2009 hi all, i recently smashed a 94 na-t over a rounderbout traveling at considerable speed within the law ofcorse. amazingly even though the force managed to flatten all 4 wheels the suspension arms and wishbones dont seem to be damaged in any way , but now the car dose not sit level at the front, the rear wheel camber is verry odd ( drivers leans alot more ) the car pulls right and feels horible through corners. i have checked the bushes for play the wishbones measure up to spec and the chassis mounts are perfect , can anybody give me some advise on things to go through to try and get the supesiondand camber back to standard, its on standard suspension all around , thanks Link to comment Share on other sites More sharing options...
JamieP Posted January 26, 2009 Share Posted January 26, 2009 Bent Chassis? Link to comment Share on other sites More sharing options...
SupraShaun Posted January 26, 2009 Share Posted January 26, 2009 Maybe a combination of several suspensions components be very 'slightly' bent? Link to comment Share on other sites More sharing options...
JustGav Posted January 26, 2009 Share Posted January 26, 2009 Bent dampers.... The list can go on... Link to comment Share on other sites More sharing options...
Homer Posted January 26, 2009 Share Posted January 26, 2009 Subframe damaged? hub issue? Could be a lot of things. I had a problem with one of the rear wheels (it was visibly toed in and had huge camber), all the components appeared to measure up and nothing was visibly wrong with them. Later found the hub was very slightly bent, again not visibly so, but after swapping with another unit the wheel was straight again. When comparing the two units and measuring there was no difference, all I can guess is that one of more of the mount points were slightly twisted. Link to comment Share on other sites More sharing options...
dr_jekyll Posted January 26, 2009 Author Share Posted January 26, 2009 oh bugger, well iv just found the gude to adjusting the camber so ill try that on the back and have the front tracked, and give that a try , if not looks like the credit card is comeing out again for parts Link to comment Share on other sites More sharing options...
Pig Posted January 27, 2009 Share Posted January 27, 2009 Have you had the alignment properly checked yet? Link to comment Share on other sites More sharing options...
adnanshah247 Posted January 27, 2009 Share Posted January 27, 2009 buckled wheels? if the wheels took impact its a very good chance they could be nackered. take them to any tyre shop for balancing and you be able to tell if there not spinning straight. Link to comment Share on other sites More sharing options...
Dnk Posted January 27, 2009 Share Posted January 27, 2009 buckled wheels? if the wheels took impact its a very good chance they could be nackered. take them to any tyre shop for balancing and you be able to tell if there not spinning straight. Did you read the 1st post ? Link to comment Share on other sites More sharing options...
Dnk Posted January 27, 2009 Share Posted January 27, 2009 oh bugger, well iv just found the gude to adjusting the camber so ill try that on the back and have the front tracked, and give that a try , if not looks like the credit card is comeing out again for parts Ive recently changed all my suspension arms etc and wish you lots of luck finding the bent parts. There is quite a lot of adjustment camber wise so if somethings bent you might be able to dial it out but whatevers bent will still be bent and potentially weakened by the impact. I'd want to take a much closer look myself rather than re track it etc Link to comment Share on other sites More sharing options...
Chris Wilson Posted January 27, 2009 Share Posted January 27, 2009 If it's flattened all 4 wheels I wouldn't trust it until it had had both front and rear subframes replaced with EVERYTING on them, suspension and hub wise. Personally I would think it close to a write off, given the costs involved Link to comment Share on other sites More sharing options...
DAT Inter Posted January 27, 2009 Share Posted January 27, 2009 Get it into a specialist or motorsport group who know what they are doing. It just sounds like a death trap at the moment. Link to comment Share on other sites More sharing options...
dr_jekyll Posted January 27, 2009 Author Share Posted January 27, 2009 yep both suframes and all on them are comeing off, and replaced , the rear of the car was striped today and its heartbreaking because all the parts seem to be fine with no signes of stress or anything, but if its changed we no the probs solved Link to comment Share on other sites More sharing options...
dr_jekyll Posted January 28, 2009 Author Share Posted January 28, 2009 (edited) ok. the rear is off and i think weve found the problem, the drivers rear top wishbone is slighly bent , unnoticeable to the eye but after mesuring in is definatle a few mm out, so can anybody tell me were i can find a replacement because there hard to come by, thanks, also is the tt rear wishbnone the same as the n/a . thanks Edited January 28, 2009 by dr_jekyll (see edit history) Link to comment Share on other sites More sharing options...
Dyer864 Posted January 28, 2009 Share Posted January 28, 2009 Hi mate ! Mines doing exactly the same, changed three arms on the back, costing me over £350 and sill i've got the problem ! popped up to "extreme performance" on the weekend to see keron, who had a front end damaged insurance write off, and bought the whole back end subframe/rear axle/hubs and all the arms for a fantastic price ! gonna swap the whole lot over and hope it cures my problem ! give keron a ring (see extreme performance on traders sect.) those upper wishbone arms are £300 odd + vat each from toyota [sHOCK][/sHOCK] Link to comment Share on other sites More sharing options...
dr_jekyll Posted January 28, 2009 Author Share Posted January 28, 2009 i will do cheers mate , let me know how you get on Link to comment Share on other sites More sharing options...
