jacko Posted April 25, 2008 Share Posted April 25, 2008 Rite.... I have a 6 speed gear knob on my TT and also wen i rang Toyota for a part the other day, it came up as a 6 speed wen i gave them the engine and model codes, but.......... i sure as hell cant find a 6th gear! Is it possible for it to be stuck or something? Or does that mean it had a different box on it? Im going to get it looked at as soon as its insured and on the road Link to comment Share on other sites More sharing options...
spidermonkey Posted April 25, 2008 Share Posted April 25, 2008 Probably not helpful but 6th is down and right from 5th Sorry, can you select all other gears easily (inc reverse?) Link to comment Share on other sites More sharing options...
jacko Posted April 25, 2008 Author Share Posted April 25, 2008 Ye all the other gears are fine. So 6th is down and right from 5th and reverse is just to the right of that? Link to comment Share on other sites More sharing options...
TurboBrett Posted April 25, 2008 Share Posted April 25, 2008 1 3 5 | | | ------ | | | | 2 4 6 R Link to comment Share on other sites More sharing options...
RobSheffield Posted April 25, 2008 Share Posted April 25, 2008 Brett, you are clearly bored But yeah, its not straight down from 5, its slightly doglegged Link to comment Share on other sites More sharing options...
TurboBrett Posted April 25, 2008 Share Posted April 25, 2008 yep:d come to see our lass at uni but shes at lecture today till 1pm spent 2 hours thismorning trying to get into there wireless network and now im here i got nothing to do:rolleyes: so its not straight down from 5th then? never noticed but i can find it:) Link to comment Share on other sites More sharing options...
Scott Posted April 25, 2008 Share Posted April 25, 2008 I thought 6th was straight down from 5th. I've certainly never noticed it move. There is a bit of a notch where you cover the reverse plate while pulling down into 6th but thats about all i have noticed. Possibly a conversion with only a 5sp box? Link to comment Share on other sites More sharing options...
spidermonkey Posted April 25, 2008 Share Posted April 25, 2008 Mine is deffinately down and right from 5th, as said earlier are you sure it isn't a TT connected to a 5 speed box? Link to comment Share on other sites More sharing options...
Chris Wilson Posted April 25, 2008 Share Posted April 25, 2008 Try and take a basic photo of the gearbox from underneath Link to comment Share on other sites More sharing options...
jacko Posted April 25, 2008 Author Share Posted April 25, 2008 i will do when its on a ramp next Link to comment Share on other sites More sharing options...
dannypunto Posted April 25, 2008 Share Posted April 25, 2008 drive it in 5th at 70mph and post here how many revs it sits at, im sure sombody on here will know what rpm a 6 speed and 5 speed are at 70mph Link to comment Share on other sites More sharing options...
Nic Posted April 25, 2008 Share Posted April 25, 2008 What is the model code of your car? Link to comment Share on other sites More sharing options...
jacko Posted April 25, 2008 Author Share Posted April 25, 2008 E-jza80-alfqz Link to comment Share on other sites More sharing options...
Nic Posted April 25, 2008 Share Posted April 25, 2008 E-jza80-alfqz It should be a 6spd 2JZGTE (TT) RZ with that model code. Link to comment Share on other sites More sharing options...
jacko Posted April 25, 2008 Author Share Posted April 25, 2008 OK, i'll get the gearbox checked out. What is the difference between RZ and SZ? Link to comment Share on other sites More sharing options...
Nic Posted April 25, 2008 Share Posted April 25, 2008 OK, i'll get the gearbox checked out. What is the difference between RZ and SZ? SZ is the NA Supra. Link to comment Share on other sites More sharing options...
Havard Posted April 25, 2008 Share Posted April 25, 2008 OK, i'll get the gearbox checked out. What is the difference between RZ and SZ? About 2 seconds...... The RZ denotes a TT. Link to comment Share on other sites More sharing options...
jacko Posted April 25, 2008 Author Share Posted April 25, 2008 ah rite ok, im new to this u c lol Link to comment Share on other sites More sharing options...
gaz1 Posted April 25, 2008 Share Posted April 25, 2008 ah rite ok, im new to this u c lol just aswell you have no little red button:D Link to comment Share on other sites More sharing options...
Thorin Posted April 25, 2008 Share Posted April 25, 2008 6th gear is straight down from 5th, as per Brett's fantastically accurate diagram. Anyone who says otherwise is wrong, and should be publicly flogged. Link to comment Share on other sites More sharing options...
jacko Posted April 25, 2008 Author Share Posted April 25, 2008 just aswell you have no little red button:D ?? Link to comment Share on other sites More sharing options...
Scott Posted April 25, 2008 Share Posted April 25, 2008 6th gear is straight down from 5th, as per Brett's fantastically accurate diagram. Anyone who says otherwise is wrong, and should be publicly flogged. Phew, thought i was going insane. Either that or i had a completely different box from everyone else. The only "to the right" motion i can feel is if i slowly come out of 5th i can feel a slight notch to the right. I assume this is where reverse would be if it wasn't locked. As i move into 6th the gearstick moves back left a little bit to be direcly underneath where it left 5th, i assume this is it coming out the little notch. I've never seen a 6 speed box where you go down, right then down from 5th into 6th. Link to comment Share on other sites More sharing options...
RobSheffield Posted April 25, 2008 Share Posted April 25, 2008 6th gear is straight down from 5th, as per Brett's fantastically accurate diagram. Anyone who says otherwise is wrong, and should be publicly flogged. Now i know its a long time since i drove mine, but how long is it since you drove yours?! The only "to the right" motion i can feel is if i slowly come out of 5th i can feel a slight notch to the right. I assume this is where reverse would be if it wasn't locked. As i move into 6th the gearstick moves back left a little bit to be direcly underneath where it left 5th, i assume this is it coming out the little notch. That will be the one, its not 'straight' down, yet neither is it a mile away. Link to comment Share on other sites More sharing options...
spidermonkey Posted April 25, 2008 Share Posted April 25, 2008 mine deffinately has a slight rightward movement Link to comment Share on other sites More sharing options...
Scott Posted April 25, 2008 Share Posted April 25, 2008 Now i know its a long time since i drove mine, but how long is it since you drove yours?! That will be the one, its not 'straight' down, yet neither is it a mile away. Yes and as i said, there is also a notch to the left as it finds the gear. The final position of 6th gear is directly below the final position of 5th gear. Link to comment Share on other sites More sharing options...
