coolent
daz
What pressure is the Blitz rad cap set to?
Do your heaters work?
As said, if it's loosing so much water then you should be able to see it coming out somewhere?
Look carefully for leaks/cracks around the rad cap on the radiator (on the plastic bit) as that is a common point of failure.
rad capis set127kpa 1.3kg/cm heaters work ok plasic bits / thanks bud
