daz Posted February 26, 2008 Share Posted February 26, 2008 i am loseing coolent from my 94 tt .full too low every 100 miles or so. put on new rad cap blitz looket every were no leaks /.can any one help me on this matter thanks Link to comment Share on other sites More sharing options...
dwayne Posted February 26, 2008 Share Posted February 26, 2008 park it on a flat surface to try and see where the water is dripping from. what does it look like under your oil cap bud? Link to comment Share on other sites More sharing options...
daz Posted February 26, 2008 Author Share Posted February 26, 2008 park it on a flat surface to try and see where the water is dripping from. what does it look like under your oil cap bud? it always park up no water on the floor at all its dry as a bone under the car Link to comment Share on other sites More sharing options...
Gaz6002 Posted February 26, 2008 Share Posted February 26, 2008 What pressure is the Blitz rad cap set to? Do your heaters work? As said, if it's loosing so much water then you should be able to see it coming out somewhere? Look carefully for leaks/cracks around the rad cap on the radiator (on the plastic bit) as that is a common point of failure. Link to comment Share on other sites More sharing options...
daz Posted February 26, 2008 Author Share Posted February 26, 2008 What pressure is the Blitz rad cap set to? Do your heaters work? As said, if it's loosing so much water then you should be able to see it coming out somewhere? Look carefully for leaks/cracks around the rad cap on the radiator (on the plastic bit) as that is a common point of failure. rad capis set127kpa 1.3kg/cm heaters work ok plasic bits / thanks bud Link to comment Share on other sites More sharing options...
dwayne Posted February 26, 2008 Share Posted February 26, 2008 what about your oil cap? worth checking your headgasket isn't knackered Link to comment Share on other sites More sharing options...
daz Posted February 26, 2008 Author Share Posted February 26, 2008 oil cap is ok no cream around it Link to comment Share on other sites More sharing options...
Gaz6002 Posted February 26, 2008 Share Posted February 26, 2008 rad capis set127kpa 1.3kg/cm heaters work ok plasic bits / thanks bud Do you mean you checked the rad? Does it loose coolant when running the car stationary? Link to comment Share on other sites More sharing options...
Ian C Posted February 26, 2008 Share Posted February 26, 2008 oil cap is ok no cream around it Sounds more like the gasket has gone between a water channel and cylinder then - water is being burnt off, no oil contamination in the coolant. -Ian Link to comment Share on other sites More sharing options...
Digsy Posted February 26, 2008 Share Posted February 26, 2008 You would be getting a lot of white smoke (steam) out of the exhaust if that was happening. Should be pretty obvious. Also the coolant system will probably be pressurising. Link to comment Share on other sites More sharing options...
colsoop Posted February 26, 2008 Share Posted February 26, 2008 Get it in the air and take the undertray off, they can mask leaks quite well. With the cover off you may be able to see more of whats going on under there. Link to comment Share on other sites More sharing options...
Scooter Posted February 26, 2008 Share Posted February 26, 2008 have you ever lost all coolant from the expansion tank, or are you topping it up every time it gets low? Link to comment Share on other sites More sharing options...
daz Posted February 27, 2008 Author Share Posted February 27, 2008 i am topping it back too full Link to comment Share on other sites More sharing options...
molak Posted February 27, 2008 Share Posted February 27, 2008 sounds like the head gasket to me. take it to a garage and test for hydrocarbons (un burnt fuel) in the coolent system. Link to comment Share on other sites More sharing options...
Chris Wilson Posted February 28, 2008 Share Posted February 28, 2008 The reservoir (expansion tank) will vent excess coolant if you over fill it. Top it to the minimum level, cold, and see what it does. The rad itself should always be brimmed full, cold. Link to comment Share on other sites More sharing options...
Terminator Posted February 28, 2008 Share Posted February 28, 2008 In older cars the original rad and matrix will show up weak points with a 1.3 bar cap. The under-tray will hold a lot of water, which will evaporate when the engine is hot and cooling fan is blasting hot air over it. Link to comment Share on other sites More sharing options...
miko_supra Posted February 28, 2008 Share Posted February 28, 2008 you haven't changed the coolant recently? mine had dropped considerably, i topped it up and it hasn't gone down since so i am presuming it was air trapped Link to comment Share on other sites More sharing options...
