My own Engine almost ready
Lucifer
I started rebuilding my Supra last year, but what with MKivStore poping up its taken a while.
Here are some pics of the Engine in the final stages.
Also I must stress this is MY own Engine in MY home Garage. This is NOT where customers engines get built, fitted or prepared.
However saying that it was build by us of course!
Spec
Block
New Toyota Block
JE Pistons
JE Pro Seal rings
Carillo H-Beam Rods
ARP Mains
ARP Rod bolts
ARP Head bolts
1.4mm Toyota Head gasket
Block painted MKivStore Blue
New starter Painted and polished
PHR Street Alternator
TRD Engine mounts - Polished + Painted
Engine mount Brackets polished
Dipstip polished
Support bar polished
Polished Stock intake and Throttle body (for run in period only then JUN)
Turbo
PHR Stage 1 Obiwan Tubo Kit
MKivstore Custom compressort housing (not shown)
HKS Genuine Manifold
HKS 60mm Wastegate (not shown)
Recireculating Dump into exhaust.
Fuel system
MKivStore Custom fuel system
850cc Injectors
MKivStore Fuel rail - Twin feed
MKivstore Fuel pump setup with dual Bosch 04 Pumps, Walbro Primer pump, Peltier Chilled Ally swirl pot.
Aeroquip lines throughout
Head
New toyota Head
Stock Guides
Ferrea Valves 5 angle cut
Not polished
Slightly ported on exhaust side
HKS 256, 264 Cams
Titan Cam gears
Im sure there is more.... I'll have a think. A duplicate is for sale @ £9400
  • Replies 52
Posted Images
cool, which phr turbo is that (size)
It is the Obiwan Street kit DBB
Looking good mate. Where did you get the belt tensioner from ?
Us we supply and make these. When I launch this engine / car fully we will be launching a whole range of engine bling parts too. Ill keep you posted Joe as I noticed we are doing most of the things you dont currently have on your engine.
Very nice mate! I'm liking the coloured block a lot.
Wonder if you could quickly tell me though, the water hose that goes around the back of the block. Is it just held on by the two bolts one on either side of the block, or is there one that holds it on the back of the block? I want to remove it so I can loose the two air lines that go to the pressure tank that I no longer have, and I want to remove the spare water exit, that I'll no longer need.
Cheers,
Tony
Nice blue :drool: What sort of prep, primer, and paint did you use....? Can it be applied to the cylinder head as well...?
Prep
An Aweful lot of hand work went into this to take off any course casting. Dremmel, DA, file. you name it itwas done.
Primer
None Direct HTA Paint
Paint
We used a Custom HTA paint mix, mixed for us by the car paint wharehouse.
LOL I have never even considered the head. I would say no, mainly for the fact you need contrast!
HTA? That's something to do with heat, right? :) What would I ask for at a shop?
So clean up and degrease the block, and then paint it with this stuff. Mmmm.
I was thinking cylinder head "instead of" rather than "in addition to", seeing as it's easier to reach. You'd have to be mad to pull the engine just to paint it :)
-Ian
