Modified tt autobox and extras
TT Paul
 Share
Guest benjiboy87
is this a tip tronic box?
who is david p? any contact details, would be interested if he could modify a tip tronic box
thanks
Currently still in my car running 550fwhp.
Valves were shimmed by David.p to change gear quicker. Keeps temps down also.
I did notice the Temps were a lot lower had several autos and the gear change is quick but does not snatch.
Autobox covered 60000km £300
Twin oil coolers £100
3400 pi hi stall £350
Fully serviced 2000km ago
Jspec box not tiptronic
Or the lot for £575.
Currently located in Birmingham box will be out due to manual conversion.
I can get pics later this wk when it's been removed.
I will have parts with me early December.
  • 1 month later...
You don't need two pairs of fluid lines, one pair will do.
You need a rear line to replace the weeping joint on the rear line of yours and a front line to repay me for the front line that I lent to you from my needed stash of bits to complete your Hybrid transmission into Supra 1UZFE VVTi build.
J_Meiser also needs a front line for his Hybrid transmission into Supra 1UZFE build.
I'll remind him.
I'll remind him.
Thanks for the reminder David, if there is a front line available, I'm interested :)
 Share
