2JZGTE VVTI From Aristo into A Non Turbo Auto
Flan
 Share
You need a supra VVTI Engine harness which will make the job so much easier
They are just very rare and hard to get hold
I do have one here if you are going ahead with it
You also need
complete supra rear sump setup
PS Pump
Ac compressor
Single wire temp sensor from water neck
Turbo Oil return rubber pipes and union for the sump
Lambda Sensor
Some of this you can use from your current engine if you need to
Cheers for the replies guys. I know it's a difficult job but it still seems easier than NA-T. Plus the Aristo engine is much cheaper than a supra one. I'll read up more on it but does anyone know if the supra auto box is compatible?
 Share
